Question about Amana Dryers
I have an model led20aw it is not heating. Heating element is good. What else could be the problem
  • roy quinn Aug 13, 2011
    what makes this wire burn into?
    Scholar:
  • 142 Answers
First make sure you have 240 Volts going into the dryer. If you do you would need to chase all the wiring for a loose connection (usually burnt). First look at the timer, then there are thermostats near the element to be checked and there is a switch mounted on the outside of the motor; it has two "bigger" wires connected to it. Sometimes the connection burns loose at that point.
Posted on May 20, 2011
2 Suggested Answers
SOURCE: getting to heating element/thermal fuse for amana model LED 20AW
I just replaced mine by taking the bottom off, but in hindsight I think I should have been able to do it by just removing the lower front panel. With long arms, you should be able to reach back and loosen the two bolts holding it in place. Good luck!
Posted on Apr 20, 2010
LED20AW Heating element
No Jim, that amount of lint is normal in all of those dryers. You should clean it out annually to prevent fires. The front panel under the door is all that you should have to take off to get to the heater coil and to clean it out.
Jan 20, 2014 | Amana Dryers
Tip
How to Change the Heating Element in a Electric Dryer?
1) When the clothes are not getting dried but dryeris running. That means the heating element needs to be replaced.
2) First of all unplug the dryer from wall outlet.
3) The heating element is located in the cabinet. Insome models the cabinet is located in rear or in some models its located infront.
4) Remove the screws on the heating element cabinetto reach the heating element.
5) You will see wires connected to the heatingelement terminals.
6) Remove the wires from element using needle noseplier.
7) Then remove the object blocking the heatingelement with the screw driver. But in some models the heating element can be removeddirectly.
8) After removing the object remove the screwsholding the heating element.
9) Theheating will have to be moved a bit to come out easily. Before removing theheating element out. Please note down the position of old heating element. Sowhile placing the new heating element you don’t face any problem.
10) Refit all the parts removed while removing theold heating element properly.
This will help. Thanks.
on Mar 20, 2010 | Dryers
No heat in my dryer
Try Google---the model number with replace heating element, etc as there are many good videos for this on You Tube. It will vary from model to model.
Dec 22, 2012 | Dryers
How do I check my hot water element?
1)Locate the upper heating element in the top access. The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to the disk.
  • 2)Set your ohm meter to the X1 or RX 1 scale to measure the continuity of the heating element. Touch each of the ohm meter probes to each of the terminal screws on the heating element. A positive reading indicates a good element. If there is no reading, the element is faulty.
  • 3)Test for a possible short in the heating element with the ohm meter. Touch one ohm meter probe to one of the heating element terminals. Touch the other ohm meter probe to the bracket that secures the heating element. If you get a reading of zero, the element is good. If there is any positive reading on the scale, the element is grounding itself and will require replacement.
  • 4)Test the lower heating element exactly as the upper heating element.
  • 5)Place the access doors back on the water heater tank, and secure them with the screws.
  • Good luck
    E.CUADRA
    Dec 03, 2011 | Heating & Cooling
    Oven won't heat, all burners work
    I suggest that you remove the upper and lower heating elements to the oven, turn the oven switch to on, then use a good digital voltmeter, and check the plug that the lower heating element was in. If you have good (200 volts or more) then purchase and install new heating elements. Turn the oven switch to Broil setting and check the same way for the top heating element.
    May 09, 2011 | Maytag Kitchen Ranges
    Kenmore Dryer -will spin but not heat and dry
    The ohms reading on a heating element should never be zero. The resistance is what turns electricity into heat. You may have gotten a bad part. Check it again with NO power to the system. Unplug it or flip the breaker to be sure. You should definately get a reading on a good element. Good luck
    Dec 06, 2009 | Dryers
    Oven will not turn on. but stove top works fine. model#jgbs07pea2ww
    A common problem is the heating element goes bad. I have had this happen and you can see a spot on the heating element which looks different from the rest of the element (a clue).
    Many ovens have two heating elements. Upper and lower. Now I am no Julia Child, but I think bake turns on just the lower heating element? And broil turns on just the top heating element????
    So I suppose you might have it on bake and it is not working. Might try broil and see if that works. If yes, then you are getting power through all the controls to the upper heating element, so good chance just the lower heating element is bad.
    If you don't get heat to either the upper or lower heating element, then I would suspect the wiring or a control.
    So far as the heating element, you should be able to remove it and using an ohm meter, get some sort of reading if it is good (I have no idea what though). Or open circuit if bad.
    Also the insulation on older ranges can "melt" back exposing live wires! This is of course very dangerous and the wiring should only be replaced with high heat range wiring which I assume you could get at an appliance store?
    Or the contacts on a control/switch could be bad. I would test this with a continuity tester or ohm meter.
    Many appliances have a wiring diagram down low somewhere. Or might find it online.
    Nov 18, 2009 | GE Profile JTP56 Electric Double Oven
    Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
    Hello there
    Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
    Best regardss michael
    1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
    1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
    2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
    3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
    Oct 15, 2009 | Whirlpool Dryers
    Need a heating element for a whirlpool range model number rf3020xkq
    Check the following link. It is for the model number RF3020XKQ.
    part select for RF3020XKQ
    On the left side bottom, check for the "search by keyword" and enter "heating element". The display on the center bottom gives you a list of heating elements. hope this solves your problem. Good luck with the machine, Please do rate my solution if accepted.
    Apr 08, 2009 | Kitchen Ranges
    Getting to heating element/thermal fuse for amana model LED 20AW
    Apr 05, 2009 | Amana Dryers
    Dryers Logo
    116 people viewed this question
    Top Amana Dryers Experts
    Tim Whalen
    Sal De
    Are you an Amana Dryer Expert? Answer questions, earn points and help others
