Question about Pioneer PRO-630HD 58" Rear Projection Television
I have the blue shadow problem on my pioneer tv i want to know how to fix it
  • Pioneer Master
  • 3,459 Answers
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changedI have the blue shadow - 578ba6c.jpg/>578ba6c.jpg
TV
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Please do us a favor and rate this solution after reading
Posted on May 20, 2011
I have a pioneer tv model pro-720hd. The picture just went fuzzy and everything has a blue shadow around it. What could be wrong?
Sounds like a problem in the blue HV convergence circuit, bad yoke or IC chip that drives the yoke coils.Could also be a bad blue CRT. Look at IC901, STK392-110 and releated components in the circuit, page 97 of service manual.
Look at the
Blue CRT DRIVE
ASSY (AWZ6603
Download Service Manual here: http://elektrotanya.com/pioneer_pro720hd_projection.pdf/download.html
May 27, 2011 | Pioneer Televison & Video
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
Mitsubishi RPTV has a blue shadow/image alignment problem
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 23, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Blue and yellow shadows appearing on my rear projevtion tv
The convergence IC's are definitely bad. This is not something you can fix yourself unless you know how to solder and are technically inclined.
Mar 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Colors are skewed on Pioneer Pro-520HD
you can replace your the convergence chips on the convergence board. The board is to identify because it has a large heat sink. The convergence chips normally starts with STK... After you find the chip, you can buy online (ebay has a lot of listing) and costs around $10. If you know how to solder, it is very easy to do. I just replace the convergence chips on myPRO-610HD and it works perfectly.
Feb 20, 2009 | Pioneer PRO-520HD 53" Rear Projection...
Red shadow?
call a tech and have them converge the tv.its either that or the focus
Jan 02, 2009 | Pioneer PRO-119 60" Rear Projection...
50" Pioneer TV blacks out and has shadow on the bottom third
yes it is worth fixing.if you r getting it repaired for the first time.
but you will have to wait for some long time to get it repaired as the tv is very old its very difficult to get the parts for reparing it.
the problem what you r facing is the problem of the convergence in your main board of the tv.
it has to be repaired.
i will advise you to get it repaired as it will work.
for doing it your self you can try clicking this link and following the given instructions in it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
Jun 25, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Hitachi 55inch projection tv with blue shadow.
Blue Convergence Ic is defective. let me know if you need to know where to get a replacement IC
May 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Pioneer elite Projection TV PRO-98
Need to replace the convergence board. Cost through Pioneer is $350.
Nov 25, 2007 | Televison & Video
Hitachi 50V500 tv blue shadows
If it's a ghosting problem that looks like this:
it's probably something you can correct yourself...
Nov 21, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Pioneer PRO-630HD 58" Rear Projection Television Logo
163 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
