Question about JVC CH-X1100 12-Disc CD Changer
Help me My cd changer says r-8 ..... what do I need to do? we have taken the cd's out ...then turned if off then on again ..... Help me please ...this is in my new car So I have no idea
  • Jay Burton Aug 15, 2013
    it still didn't work
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
Hold the eject button on the disc jockey for 5 or more seconds it should reset the unit and fix your problem
Posted on May 18, 2009
I have a 2001 Nissan Skyline 300gt and there is a cd jammed inside any soloutions please
Seems you have mechanism problem with CD changer. Firstly, need to taken out your CD changer and remove your jammed CD. Clean and check the mechanisms. Then re-try your CD.
Regards,
Dec 16, 2010 | Boss Car Audio & Video
Cds are stuck in the changer
Hi.
Ensure that the CD changer is powered, check cable and connection.
Disconnect battery for one minute and try again.
If that does not work, disconnect battery again, and try repeatedly pressing the eject on changer while someone else connect power back.
If that does not work the changer must be taken apart to remove the disks. Disassembly involves removing external cover, and usually it is not too complex.
Regards.
May 22, 2010 | Jeep Liberty Six Disc CD Changer -...
Hello - My 2001 VW New Beetle Monsoon radio reads "No Changer". What can I do to fix it?
If it's saying "No Changer" then it's possible that one of the connections between the radio and the changer itself has become disconnected, a possible blown fuse or worse still the changer itself has failed.
First of all check the fuse box, make sure there are not any blown fuses there and if you have to refer to your VW manual if you got the CD multi-changer with the car.
Locate the changer itself and check that any leads has not become disconnected and check behind the radio itself to make sure nothing has become disconnected.
Once you have checked all connections on the radio and changer, and checked the fuses, and you are happy that all seems well then you can try your changer again.
Don't forget to replace any blown fuses you find!!!
If you need anymore help or the changer still is not picked up by the radio please post back.
Good luck.
Aug 03, 2009 | USA Spec SCD-VW44 6-Disc CD Changer
Cd magazine stuck in the cd changer in mercedeze e320
CD magazine stuck inside the changer in a 1999 E-320 Mercedes Benz.
Apr 13, 2009 | 2002 Mercedes-Benz C-Class
Pinout of Round Connector on CDC A08 ?
See this diagram.
http://fileshare.eshop.bg/index.php?what=search2
(search for CDC A08 if link doesn't work)
Basically, 12v to pin '3' (with notch at top, it's the top row, third pin from the RIGHT) and ground to outter jacket of the connector. Push eject button, works a charm.
Cheers.
Mar 27, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Not playing!!
hi the A09 has to be married to the head unit, unless your model is the A09 PSA.
Mark
Apr 02, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Question on wires
if the conector is this here you have it
Apr 30, 2007 | Kenwood KDC-CX87 10-Disc CD Changer
Volume is uncontrolable
Hi sounds like you have the audio out from the cd changer connected to the RCA/Phono out of the radio. double check that the output from the CD changer is going into the correct phono/rca connector regards Mark www.carradiospares.co.uk
Apr 04, 2007 | Panasonic CX-DP88 8-Disc CD Changer
SEEKING DATA CABLE FOR JENSEN RF10DC
Go to this link and click "find a manual"; http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=13670&langId=-1 It is not for your model exactly, is for a rf10ch, but look on page 12 it shows the standard cable for this sort of unit - it looks like a 15 ft standard din 8-pin (7/1/315) connector. The cable should be well shielded. With this information any electrical shop should be able to make one up. or contact these guys - they have taken over customer service from jensen, but i am unsure how good they are - please post back if you have any feedback on this. Hope this helps :)
Mar 19, 2007 | Jensen RF10DC 10 CD changer
Number 8 flashes on display screen and disk changer is stuck
The #8 indicates either the settings for the amplifier is too high so tryi turning down both channels and/or the fuse Si3 on the amplifier panel inside the wurlitzer is blown
Aug 19, 2006 | Wurlitzer Jukebox 1015 One More Time...
JVC CH-X1100 12-Disc CD Changer Logo
213 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
