Question about Mitsubishi WD-52531 Television
I was watching my Mitsubishi WD-52531 TV and all of a sudden there was a pop and TV turned off. I let it cool down for about 15 minutes then turned it back on and there was sound but no picture. I checked the lamp indicator light and it is not on. Just wondering what it could be? Thanks for any help, Matt Biederman
  • 373 Answers
Did you take the lamp out and look at it to see if it is shattered inside the bulb?
Posted on May 20, 2011
  • TV Doctor
    TV Doctor May 20, 2011
    There is an access door and the lamp can be easily removed with a screwdriver and there is also a reset button on the front that you can reset using a ball point pen. Look carefully for the system reset button
Hered a pop sound and now tv wont work
From what I researched, after changin a bulb on these TV's some capacitors fail and "pop" on the DM board, You will have to take it apart and re-cap the caps on the DM board 1000uf 10v (4 - 7 of them). This solves the problem in most cases
Apr 24, 2012 | Mitsubishi WD-52531 Television
WHERE CAN I FIND THE BALLAST IN THE MITUSUBISHI WD 52532 MODEL
hint: the two pins the lamp plugs onto go directly to the ballast which is really a power supply for the lamp.
not clear from all you have said if ballast is the problem===these sets had a lot of issues; anything, even too much dust on the fans inside will shut it down...........
Mar 26, 2012 | Mitsubishi WD-52531 Television
My Mitsubishi WD-52631 went "POP"
No,probally a capacitor the help the power supply board to work or other boards to work is blown.Call some tv shops get a best quotes prices,get a tv tech out to it fix,if ur tv is out of warrenty.
Jun 17, 2010 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi WD-52531 not working after replacing the buld.
Check to make sure the lamp is in correctly and that you've closed everything up properly. If you don't close the cover, the sensors will tell the computer in the TV that the door is open and won't let the TV turn on.
Other than that, could be a bad lamp or bad ballast.
Always buy OEM lamps, or better-than-oem equivalents! Philips lighting is the best lamp manufacturer out there for these TVs. They invented the thing!
Buy from Authorized distributors, and don't buy the "cheap" stuff. savnig 20 bucks will cost you more in the long run--believe me!
Feb 05, 2010 | Mitsubishi WD-52531 Television
Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Jul 18, 2009 | Mitsubishi WD-52531 Television
Same problem with Mits WD-52531
The first thing to try is to reclose the access door to the lamp area. There are interlocks there that may be marginally connected. Try to reclose all access doors and report the results here.
Thanks,
Dan
Jun 29, 2009 | Mitsubishi WD-52531 Television
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52531 Television Logo
195 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
