Question about Maytag Dryers
Dryer temp control is not working right. Dryer keeps getting hotter at any setting.
  • Kelly
    Kelly May 20, 2011
    bI can help you but I need to know your Model number. The model number should be on the data plate inside the door on the left side of the cabinet face.
    I am pretty sure you have either a stuck thermostat or a problem with the blower / fan. With a model number I can guide you to the parts locations.
    Kelly
    Problem Solver:
  • 6 Answers
CLEAN THE FILTER,PROBABLY ON TOP,GOOD LUCK
JOE
Posted on May 20, 2011
Just replaced high imit thermal fuse. The dryer belt squeks after 30 minutes on high manual mode. It seems the dryer is running much hotter than usual maybe causing the belt to squek. Any idea???
You may possibly have a bad temp control stuck on that caused the hi limit to open in the first place. That may be why you have a hotter than normal dryer. Temp controls are usually near the hi limit. A round disk with either 2 or sometime 4 wires hooked to it. Also check for a possible block vent keeping the hot air from venting outside.
Mar 20, 2015 | Dryers
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
Temperature knobs won't change temperature Chevy Tahoe
You likely have a HVAC control head failure. The rear heater problem is likely a door actuator, the rear wiper is likely a open wire in the door jamb in the top. The gauges are likely a cluster failure.
Oct 17, 2012 | Chevrolet Tahoe Cars & Trucks
GEW9878PW! electric dryer, evidently it isn't going into cool down mode
On the late models with electronic controls you either have a bad control OR a bad thermistor. The thermister mounts on the blower housing and the control measure the resistance drop on it as them clothes get dryer. That along with a pair of sensors that detect moisture inside the drum. As the clothes get dryer the less moisture is sensed until the control advances over to cooldown and finally off. So if the thermister is not working correct the temp would be off. The control is way more money than the thermister. I would clean it up first and make sure no air restrictions are causing overheating.
SERVICE MANUAL FOR DUET DRYER IF ON MY MANUAL PAGE AND FREE
Sep 30, 2012 | Whirlpool GEW9878LW Electric Dryer
I have a white Rodgers ac thermostat and the temperature in my apartment stays on 88 no matter how low I set the temp. If I turn it off, of course it gets even hotter. This started happening when I pressed...
I'm not quite sure I understand what you have done but, make sure your compresor(outside is running and, that you don't have the thermostat set to "fan". You want the display to show "cool" and then adjust your temp. It sounds like you have the system set to fan and not cool. Provide me with a model number and I will see about getting you a manual.
Jun 04, 2011 | White Rodgers 0754-1 Electric Water Heater...
I am a florist with a 26 feet src refrigeration box (unit), I cannot control the temp at the desired rate, it keeps fluctuating to a higher (hotter) temp. Need your advise
your going to adjust the thermostat setting if your thermostat is digital type you press it yuor desired temp. ex from 10 to 1 to adjust it to cool if your thermostat is analog to adjust it to cool rotate the knob clockwise to adjust the setting to cool but observe it to get you desired temp.
Mar 02, 2011 | SRC Refrigeration LD126-4 10'6' LongDoor...
My oven gets too hot. flame doesn't shut down
The problem is the temperature probe has failed. This is inexpensive usually and easy to replace. This link should help
http://appliancehelponline.com/oventempprobe.html
Jul 08, 2010 | Premiere Ranges SCK34 Gas Kitchen Range
Replaced high temp sensor on whirlpool front loader
The high limit thermostat should have been replaced also.
If there are no obstructions that will fix your problem.
Mar 13, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
