Question about Hampton Bay Heating & Cooling
EXCESSIVE FAN WOBBLE AT HIGH SPEED Hampton Bay Model Edisto 844 854
    Brigadier General:
  • 4,736 Answers
Two things you need to check: One or more of the fan blade irons may be loose or the ball on the end of the fan motor's mounting rod is not properly fitted into the ceiling-outlet bracket. If it only happens on high speed, I'm betting on the mounting rod ball not sitting in the ceiling bracket, properly.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 20, 2011
My Hampton Bay fan instlled on a slopped cielling on High speed I hear TIC TIC TIC when I rduce speed o MED no more TIC TIC what is the solution. Does the model 459-664 can it be installed on a sloppe
What do you expect to get from a store brand fan? They're cheaper because they use lower end parts. Always look for a fan with at least a 13 degree blade pitch for better air movement.
Mar 28, 2014 | Hampton Bay Dryers
Why not turn the fan on high speed or because my fan does not turn. Is 54WDL Hampton Bay model.
You should never have to use a fan on high speed inside the house unless it's a cheap store brand with no decent blade pitch.
Aug 02, 2013 | Hampton Bay Dryers
Manual for aHAMPTON BAY ceiling fan campbell
Fan is a little noisy on med or full speed, is there a place to oil it? The fan is level & doesn't wobble.
Apr 02, 2013 | Hampton Bay Dryers
New fan with downrod wobbles when on high speed and low speed. Does not wobble on medium speed. How do I stop the wobble completely?
Measure from the same spot on the ceiling to the outer most tip of each blade (by rotating to the tape). The distance should be the same, if not check fan blade screws for tightness. You might have to bend the fan blade brackets a little to get the same measurements, if the screws are all tight. If all this lokks good, you might to use a balancing kit...just follow the instructions...it's not too bad to do
Feb 18, 2010 | Hampton Bay Dryers
Hampton Bay fan has a grinding noise
I have worked on many fans because this fan is ten years old. I want to say that this fan has ball bearings in it. Have you tryed WD-40? If so did it work? Are you able to look inside, through the top of the fan to see if some thing is in its way?
Nov 04, 2009 | Dryers
Hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
No middle speed.
Replacing the pull switch (reostat) should have solved your problem. Try going to the internet at www.google.com and in the Google search box enter "Hampton Bay Fans homepage". If any of these suggestions have been helpfull, please rate my solution. Thanks D. Lange
Jul 31, 2008 | Hampton Bay Sidewinder 04890 Ceiling Fan
Fan makes noise
try to find the manual through the internet. Look for model number and name of product then click manul to your chosen then it should be no problem to help you find it better!
Jul 18, 2008 | Hampton Bay Cessna 04313 Ceiling Fan
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Heating & Cooling Logo
145 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
AJMAL KHAN
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
