Question about GPS
I have an RS12 GPS antenna that does not work on a Raymarine 620 chart plotter
  • 3,018 Answers
  • It should. They are both 50kHz-200kHz duel frequency operational, both are pined out the same. The antenna should absolutely work. It would seem you have an issue with the antenna connector on the 620 unit or the antenna from the RS12, one or the other.
Regards, Tony
Posted on May 20, 2011
Raymarine dsm300 Circuit breaker keeps tripping g when connected to chartplotter
either the cord to the chart plotter is faulty or the chart plotter itself is dead short
have an electrician do an insulation test and circuit test on the cord and plotter unit
Jan 08, 2017 | Raymarine Boating
I have problems with my plotter Raymarine Rc 435 chart plotter.This plotter can not location my ship to do.What is problems?
Be sure there isn't any aluminum in close proximity to your GPS antenna, or that your antenna is not to close to other powerful electronics. Aluminium reflects electromagnetic signals and other electronics emit EM fields as well causing disruption of your GPS signal reaching your antenna.
Sep 26, 2014 | Raymarine Rc435 Chartplotter
I have a old raymarine c80 navigation sometimes it gives me a fix when i turn it on and sometimes it will not. Do i need a new antenna if so what kind.
The issue is related to the antenna, either bad connection, low voltage or faulty gps. Start by checking the voltage supplied to the antenna (most probably through SeaTalk from the plotter), if you find this to be 11V or bellow - beef it up by adding external 12V. You can also check the wiring, if all looks ok - it is time to get a new gps antenna. Raymarine has a retrofit pack for the new RS130 which also includes SeaTalk ng converter. With some luck it's only the power...
Oct 22, 2013 | Raymarine C80 GPS Receiver
My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Apr 13, 2010 | Raymarine C80 GPS Receiver
The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Sep 27, 2009 | Raymarine A65 Combo GPS...
Rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
Jul 12, 2008 | Raymarine RL70CRC GPS Receiver
Raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
May 05, 2008 | Raymarine RL70CRC GPS Receiver
I have a Raymarine L755 chart plotter that is continuously rebooting. It shows the initial screen and holds it for about 5 seconds and then beeps, reboots and the cycle starts over.
Make absolutely sure that all of the buttons are clear (not stuck). After that, begin by unplugging any external interfaces (including the chart card) one by one to determine if one of those is the culprit.
Apr 28, 2008 | Raymarine E120 GPS Receiver
RL70CRC crashes with new "Wide" C-map cartridge
get a new burn on the chip, I have seen this issue on a particular burn.
Mar 22, 2008 | Raymarine RL70CRC GPS Receiver
GPS Logo
96 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
