Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Hello, i have a fisher and paykel dishwasher two draw system. It completed a wash cycle and then flashed and beeped E1 (a flooding error, as i looked it up) i have cleaned the whole system out and dried it and put it back on to wash. It wont start the cycle it flashes the dish symbol then a few seconds later flashes the E1 again, i have it switched off at the wall currently. will i have to get someone out to fix it? thank you
  • 10,515 Answers
Is it F1 or E1?
F1 code - F-1 means flood condition, F1 means that the unit is detecting water underneath the bottom drawer. pull the bottom drawer out and put in on the plastic tabs on the side near the bottom just behind the front panel, pull the drawer out far enough to slide a towel behind the drawer,you need to soak up all the water you can , then you may need to use a hair dryer to dry the sensor in the left back corner, when the sensor detects that there is no more moister in the pan the F-1 will go away, sometimes the cause for this is stacking the dishes to high and the lid doesn't shut down tight and seal the drawer.
If the problem is not resolved by the above procedure, you might be looking at replacing mains filter board which would cost around $50. However, at this point i would rather advise you to call a tech to make sure what exactly the problem is.
E1 is another issue with few models and more likely the concern is faulty controller. The buttons are usually unresponsive in this case.Tech are recommended in this error.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 20, 2011
Fisher paykel dd605
F1 (or E1) is a "Flood" fault and means there is water in the bottom pan. This is beneath the bottom drawer. The sensor is in the left, rear corner of the base pan. Any kind of leak, including over sudsing or split hoses or or lid not down fully due to tall items in tub, can cause this. Remove the lower drawer, dry the water from the pan bottom, reinstall the lower drawer and check operation. If this error recurs you must find the leak and correct it.
Sep 26, 2016 | Fisher and Paykel Dishwashers
On the 2nd draw will start washing but not even a minute flashes the F2 error and stop washing, what this means?
Hi Francesca, The link below is a short youtube video on how to simply fix f2 on your fisher and paykel dishwasher.......CHEERS..
https://www.youtube.com/watch?v=qP_X9iG0f-g
Mar 29, 2016 | Fisher and Paykel Dishwashers
Why does my Fisher and Paykel DD605SS stall part way through wash cycle?
I'm not sure of this, because the manual does not have an error with a E. I can fine error F4. It says it encountered a faulty temperature sensor or element. If the heating element burned through the night you circuit breaker tripped (Sure it was not the ground fault circuit breaker?), then the dish washer can't heat the water, so the program can't continue. The program stops (waits) till the chosen temp is reached. If the water stays cold the program can't go on.
So also check the heater in the machine. I hope you are aware everything in the machine runs on high (or at least dangerous) voltages, so be careful not to work in the machine when it is still connected.
Jun 15, 2014 | Fisher and Paykel Dishwashers
How do I clear the error on a Fisher and Paykel DW60CSX1 error message E6
to fix essentially you need to reboot... unplug at wall - wait about 30 seconds - 1 min then replug. should reboot and be back to normal.
if you can, pull drawer out at end of cycle so condensation does not cause this problem going forward... ours does this when it's higher humidity
May 18, 2014 | Fisher and Paykel Dishwashers
F&P Dishwasher Fault
Most likely you have fault code E1 which means door is not shut properly. It is likely the door springs need adjustment as the door might be opening mid cycle.
Refer manual
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/599350D_DW60ugm_AUSGw.pdf
Mar 18, 2014 | Fisher and Paykel Dishwashers
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Dishwasher error
The error was a flood fault, water was not draining from either of the drawere, I removed the bottom drawer, dried drip pan and used hairdryer to dry fault sensor, the dishwasher then reset itself and works fine.
Dec 31, 2008 | Fisher DS603W / DS603B / DS603I Dishwasher
Fisher and paykel dishwasher
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel dd-603ss
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
There are three possible scenarios; 1. Defective lid motor(s)...Each drawer has two lid motors that pull the lid tight to the drawer when the cycle is started. (this was very common on early models) 2. Something too tall was placed in the drawer preventing the lid from closing completely. OR 3. (only seen this once) the drain hose developed a crack causing water to leak only when draining. Hope this helps....
Jun 06, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
85 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
