Question about Toro Electric Trimmer
Have Toro Model 1100 Electric trimmer. Need to know if there is a blade assembly part available that will fit this model. I prefer the blades to string. Thanks, dg
  • 31 Answers
They do not make too many blades that fit electric trimmers as the shaft is usually smaller that the gas models.
Posted on May 20, 2011
I have an 1100 TORO Weedeater with the "push tabs" to remove the spool. Thru use/mis-use, the "tabs" are all the way in and the spool will not release. There is still line on the reel...
All I know to help you would be parts replacement as plastic parts are wear items and have to be replaced. Here is a parts w/diagrams breakdown of the 1981 model year Toro 1100 trimmer. I hope this can be of help. You can order parts here to replace your "worn out" string head and spool.
http://www.partstree.com/parts/?lc=toro_consumer&mn=51300%2C+1100+Electric+Trimmer%2C+1981+%28SN+1000001-1999999%29
May 12, 2011 | Toro Electric Trimmer
My Toro 12" Trimmer (Weed eater) needs a new screw down cap to hold the spool in place. Home Depot no longer carries them. That's wheree I got the last two Weedeaters.Please give me instructions as to...
Your Toro electric trimmer parts are readily available through www.partstree.com . However, to avoid having to pay $10 in shipping for a $5 part, you should try to find your local Toro dealer. They probably have the part in stock. Go to www.toro.com and search on the dealer/distributor locator to find your closest dealer.
You will need to know the model number (5 digit) and serial number for your trimmer. These can be located on a small sticker on the trimmer.
Oct 14, 2010 | Toro& Electric String Trimmer
I have a 22inch Craftsman Hedge Trimmer, Model No. 315.81591. When trimming a hedge near a chain-link fence, one of the steel links from the fence got caught between the blade guard and the cutter blade. ...
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Sep 27, 2010 | Craftsman 22 in Hedge Trimmer
Have Oster model 23-51f fast feed trimmer. Took the blade off havinv trouble putting parts back together namely small copper plate approx. 1-cm long, also having trouble getting the blades to fit together...
We also have these model clippers and have found out that the modelo number has been updated to 76023-510 type in Oster professional products for more info....hope this helps
Sep 22, 2010 | Oster 76915016002 Hair Trimmer
Refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
Apr 11, 2010 | Toro& Electric String Trimmer
How to change my rotor blade on my toro
Is there an easy way to install rotor blades on a Toro Model 38430 snowthrower?
Mar 03, 2010 | Toro Garden
Mulching blade replacement for Toro GTS 6HP
goto toro website and use model of machine to get blade model and use blade model in google to get prices and then order them
Jul 06, 2009 | Garden
Toro Electric Trimmer Logo
215 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
