Question about Toshiba Computers & Internet
The model of my laptop is TOSHIBA SATELLITE U400 MODEL NO. PSU40C-DW208C the problem is the backlight of the LCD is built in and no power on it, thats why i cannot totally see because its very dim color, but all the software and operating system is working what am i going to do? to buy a new LCD or ask somebody to fix the backlight
  • 734 Answers
Greetings,
It may not be the backlight, it may be the screen inverter which is a reasonable replacememnt. As a laptop specialist in my town, I always order both the screen inverter and the LCD unless both are sold combined.
Fixing a backlight is one of the most difficult laptop repairs possible to attempt. 1. You're not going to fix it. 2. In replacing it you'll have to do such delicate hand-soldering that even I don't attempt it any more and I'm VERY good with my hands.
So, friend, please order a new LCD and screen inverter and you'll be just fine after having someone spend about 1 hour replacing both.
Kind Regards,
Selk
Posted on May 20, 2011
When i power my toshiba laptop how do i test my power inverter or back lite
The plastic frame in front of the LCD screen is the Display Bezel.
The screen Inverter is mounted at the bottom of the Screen Frame.
[The LCD screen is an assembly of layers. There is a metal frame resembling a picture frame; which keeps these layers in the factory set alignment; the Screen Frame ]
Therefore easy access. Just remove Display Bezel.
To test a screen Inverter requires a sensitive multimeter; read fairly expensive,
http://www.fonerbooks.com/test.htm
Due to the above, ease of access to replace, and generally low cost; the screen Inverter is just replaced.
Then on to the Backlight if this doesn't repair the problem.
Which brings me to this;
Safety
https://www.laptopscreen.com/English/model/Toshiba/SATELLITE~A100/
The Toshiba Satellite A100-S8111TD Notebook PC, uses a single CCFL for a Backlight.
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to it's larger 'cousins' used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
View the last 8 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
This means it is Highly breakable. Costs more in money to just replace the entire LCD screen, (Which has the Backlight built-in),
but cheaper when you compare to life, and limb.
Jus sayin'.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 22, 2013 | Toshiba Satellite A100-S8111TD Notebook
Are the display bands compatible?
1) Toshiba Satellite P300-13j LCD screen example,
http://www.screentekinc.com/Toshiba_Satellite_P300D-13J--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Thin Film Transistor (TFT) Active Matrix LCD screen, that is WXGA, and uses one CCFL for a Backlight.
2) http://www.lcds4less.com/ToshibaLaptop__Toshiba_Satellite_P300D-12L__laptop-screens.html
Thin Film Transistor (TFT) Active Matrix LCD screen, that is WXGA, and has 1 CCFL for a Backlight.
There is a pretty good chance. The screen Inverter and LCD screen are a matched unit. I would remove the screen Inverter from the P300-12L, and use it also.
Looks like this,
http://www.lcd-inverter-shop.com/Toshiba/Toshiba-Satellite-P300D.html
If I may ask;
1) Is there obvious damage to the LCD screen?
2) If there is not obvious damage to the LCD screen, have you used an external VGA monitor with the laptop?
To see if the problem is the graphics chipset, or the video cable, or inside the Display Assembly.
A) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P305/take-apart-notebook-1.htm
B) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
Post back in a Comment.
Regards,
joecoolvette
[Primer:
An LCD screen cannot produce light by itself,
(Click on the monitor icon,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/ )
It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
LED stands for Light Emitting Diode
CCFL stands for Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Observe the last 8 photos especially. This article shows you that the LCD screen is an assembly. It is composed of layers. Just like the 3M company's tutorial. Also shows general instructions for replacing a Backlight.
A screen Inverter is used to convert the power from the laptop, for the LCD screen, and Backlight.
It is a small circuit board, and is usually mounted towards the bottom of the LCD screen, and behind the Display Bezel.
A CCFL, (Or two of them), uses a screen Inverter.
LED backlighting however, may or may not use a screen Inverter.
Using LED's for backlighting is relatively new, when discussing backlighting technology.
Some of the first designs of LED backlighting does use a screen Inverter.
Newer designs do not seem to.
90 PERCENT OF THE TIME the problem can be attributed to a bad screen Inverter.
Aug 21, 2012 | Toshiba Satellite Computers & Internet
Toshiba satellite backlight
Mohammad,
Toshiba Satellite P100 screen Inverter replacement;
1) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
(You can click on any photo to enlarge it. At the top, and bottom of the page are the page numbers. They are in white; Page1 :: Page2 :: Find another model )
2) Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight (Present technology) is a CCFL, or a series of LED lights.
The Toshiba Satellite P100 series of Notebook PC's uses a CCFL.
Average size is approximately 2mm Thick, and the length is close to the height of the LCD screen. 2mm is a little larger than 1/16th of an inch.
This means the CCFL can be broken quite easily, as it is fragile. (You also DO NOT want to be cut by a Fluorescent lamp )
A screen Inverter converts the power from the laptop, for the Backlight, and LCD screen.
As previously stated in a Clarification, 90 PERCENT OF THE TIME the fault is the screen Inverter.
Regards,
joecoolvette
(I never request commendations, but thank you for offering.
We, the older techs here, feel that is begging.
3 years at FixYa so far.
Regards,
joecoolvette)
Mar 23, 2012 | Toshiba Satellite P100 Notebook
Hi, I have toshiba laptop satellite U400-138, model psu44E i formatted it and i installed the OS Vista all are working except on audio device on high definition could you kindly help me or where...
You should be able to find all Toshiba product downlads by going here. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp makre sure you have the whole model number which is the U400-???? I tried what you have here but there was no such model so I am thinking that this is not the entire number or the wrong one. Click on product support and it will open a window below it then click on laptop, select Satellite, and to assist in finding your model enter the model number in the model finding filter box. It should find your model and when you click on it, it will take you to all of the downloads for it.
Apr 23, 2011 | Computers & Internet
NO SOUND ON MY TOSHIBA Satellite U405
It is probably a driver issue. First check the device manager, from the Control Panel. A red triangle with an X or a yellow triangle with an exclamation point indicate that the issue is with the driver.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download will let you search for your model and download the XP sound driver.
The specific driver may be: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2043975&rpn=PSU41U&modelFilter=&selCategory=3&selFamily=1073768667# (using the Satellite Pro U400-S1001V above)
I hope this helps.
Jul 16, 2010 | Toshiba Satellite Pro U400-S1001V Notebook
Xp Drivers needed for Satellite U400-138 to downgrade from Vista Home premium
Yes you can downgrade it to windows xp. go to toshiba website www.toshiba.com and from there you can download the drivers for Windows XP. befor installing Windows XP please download the Network driver and save it on a CD or any other driver. Then install Windows XP. Install the network drivers, connect to the internet and install the other drivers required.
Thanks
Oct 24, 2008 | Computers & Internet
Computers & Internet Logo
118 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
