Question about Troy Bilt Reverse Belts 5 Of A 97075 Built
Trying to replace drive belt on troy built pony lawn tractor, took the lock nut off trany pully, cant get belt over var speed drive pully, help
  • 710 Answers
If you remove one of the springs, I believe the small one, from the idler pulley, you can get the belt on. Then put the spring back on.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 20, 2011
How to adjust drive belt on troy-bilt pony tractor
pony lawn mower? replace the drive belts.
Mar 04, 2017 | Troy-Bilt Garden
Drivebelt routing diagram for a troybilt pony lawn tractor
oh oh big trouble...make sure you installed correctly re check ever thing is there a twist in the belt? not riding true on idler pully? correct belt?is belt cutting into guard housing any where? is the belt making howling noise? use veernier caliper to check dimensions of old belt to new belt.I once x out a drive belt with a generic one that did the same thing. my solution dont buy cheap chinese belts stick to OME belts as the chinese ones may not fit as intended.
Jul 09, 2014 | Troy-Bilt Pony Garden Tiller
Change blades on a lawn tractor pony? troy built
just jack it up so you can get under the deck and unscrew the bolt on center of ech blade take note on how the curves of blade are angled do one at a time incase you forget but bolt back up tight and you are ready to cut if you try to resharpen the blades make sure you balance them or they will mess up the deck bearings
Nov 02, 2010 | Troy Garden
Troy built lawn tractors, belts
You may have a pully that is not spining freely. Or you may have a pully that is not positioned straight. Ariens had a problem with that. so your troy built may have the same.
Apr 19, 2010 | Garden
I have a Troy Built 6605 lawn tractor. The engine
check your belt might be off a pully or maby your spring is off
Nov 09, 2009 | Garden
Drive belt problem
ck var speed pulley for movement on middle part
of pulley
Jul 29, 2009 | Garden
Troy Bilt Reverse Belts 5 Of A 97075 Built Logo
171 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
