Question about Samsung 7.3 Cu. Ft. Electric Dryer
I have a Samsung DV210AE Dryer that is 3 weeks old, everything works on the dryer except no heat and it is not showing any codes what do I need to do. Thanks!
    Scholar:
  • 142 Answers
The first thing to check is if you have 240 Volts going into the dryer. The display, lights, and motor run on 120 Volt but you need 240 V for the element.
Posted on May 20, 2011
  • coopr5 May 23, 2011
    how about after that?
  • Henry Leunissen May 24, 2011
    Well, that is when the work starts. The first thing I would do is disconnect the dryer and inspect the wires. Of you see a wire or wire connection that looks like it has overheated that is probably where the problem is. Look at the element, thermostats, timer and heat selector switch. I hope you can read the wiring schematic that comes with the dryer. You would need to look at the schematic and find the pass for the 240 Volts to the element and check for continuity all the way from the time to the element. This could take some time.
How di i reset my samsung dryer
Did you give it plenty of time to cool down before you moved it? If not, you heating element could have opened - if everything else seems to work except heat, but you should also check the thermal switch.
Jan 18, 2012 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
My DV210AE dryer will not stay on unless I hold the power button in.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 18, 2011 | Samsung Dryers
Samsung front load dryer will turn on but not spinning or drying. I was wiping it out and turning the drum I heard a snap sound.
I was cleaning mine and doing the same thing last night. Washed a load of clothes tonight and went to dry them and everything works on it except it won't spin or heat. Heard the same type of popping noise last night cleaning it out. Have you found any solutions? Mine is just over a year old. I did some reading and thing that the dryer belt came off its assembly possibly. Have you found a solution?
Jan 10, 2011 | Samsung Dryers
Our dryer is a little over a year old. Everything seems like its running ok except for the fact that there is absolutely no heat. Any ideas?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | LG DLE2512W Electric Dryer
The dryer will not heat. I have no error codes and everything else works fine. I did order a heating element assuming that was the issue but now wonder if I would've had an error code and it could be...
heatman101
Oct 05, 2010 | Samsung DV337 Electric Dryer
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
KENMORE GAS DRYER - MYSTERIOUS HEAT PROBLEM
Most times I replace the coil assy. on gas control valve. OR could be the sensor.Or both.
Nov 27, 2007 | Kenmore 73952 Gas Dryer
Samsung 7.3 Cu. Ft. Electric Dryer Logo
423 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
