Question about Mtd Craftsman 4Cycle Mini Tiller
How many revolutions to tighten the recoil spring
How to put a recoil spring back in i took apart a recoil starter for a 97 polaris snowmobile and the spring popped out and i cant put it back in
HAhaha, oh this is so funny to me cause i suffered with the same problem, you have to grip the spring with needle nose pliers and wrap it tightly back arround, gripping the new layer every revolution, it sucks i know, then VERY CAREFULLY place it back it the spring retainer
Jan 18, 2010 | Polaris New Genuine Polaris Snowmobile...
Tip
Replace Recoil Rope on Lawn Mower Engine
1) Remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope.
This is the area that causes so many guys a lot of extra trouble!
2) Locate the string that is left and the hole it is threaded thru
3) Determine how much string has broken off of the rope that came out
*Note: if more than 1 inch is left, then the rope needs to be replaced
4) Obtained a length of rope appropriate for your engine, it is always better to have too much rope.
You can always shorten if it is too long.
Make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) Wind the rotor in the direction of what the rope would pull,
(this will tighten the spring) until the spring is completely wound.
Remove 1/2 to 1 revolution.
6) Install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
Tie a knot in the end of the rope, leaving a 3/8" tail free.
Then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
9) When the unit is functioning proplerly, re-install housing onto engine.
on Dec 04, 2009 | Garden
How to put together a toro recoil
first you put the rope into place then place the spring in the center lock ,if its out then you tighten up the spring by turning it in the direction that will pull rope back in once at the end of recoil send rope into pull hole, hold it tight and let it coil up slowly,reattach to machine and your done.
Jan 14, 2010 | 2005 Suzuki RM-Z 450
How do I wind a stihl ts400 pull cord
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Nov 21, 2009 | Garden
Starter rope pulley will not pull the rope back into the leaf blower.
Most commonly, the recoil rope rewind spring is broken. However, inspect the recoil housing assembly first to make sure no debris or rope fragments have prevented the rope rotor from rewinding. Always remove the spring 'AS A LAST RESORT'. Many rewind problems can be solved by inspection of the rotor and not have to remove the spring. In case you do, I will include instructions on how to re-install.
Nov 21, 2009 | Craftsman Garden
STEP BY STEP DIRECTION. REPLACE STARTER ROPE. MIGHTYLITE BLOWER MODEL #UT08520
Nov 14, 2009 | Garden
CAN'T FIGURE OUT HOW TO RE-STRING PULL CORD
Nov 13, 2009 | Poulan Garden
I pulled the cord off my homelite 2 cycle leaf blower. can it be fixed?
Yes,
Nov 08, 2009 | Garden
Starter recoil spring attachment. It clips into the cover at one end but I cannot see how it attaches to the hub of the pulling wheel
An IPL for a Oct 2004 455 can be found here:
http://weborder.husqvarna.com/order_static/doc/usa/2004/I04000/I0401113.pdf
There as a starter detail page but it may not answer your question.
I bend the inner portion of the recoil spring until the center hub can engage the retaining device located on the inner end. The inner end of the spring passes through the hub and a small ring retainer and spring tension keeps it in place. You will need about 2 revolutions against the spring for the recoil to operate properly. HTH
Lou
Oct 05, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
Sep 04, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Mtd Craftsman 4Cycle Mini Tiller Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
