Question about Aiwa NSX-DS50 Shelf System
I have aiwa NSX-VC520 the aux cant work anymore but cd tray sometimes it works sometimes not but my concern is the AUX.
  • 298 Answers
SOURCE: Aiwa NSX-KT9
Try replacing the Carousel belt.
Posted on Feb 29, 2008
  • 36 Answers
SOURCE: Aiwa nsx-ma845 cd tray stuck
CD drives have rubber belts and wheels - 5 years is a long time, perhaps these are worn out. A new CD/DVD drive is very inexpensive.
Posted on Dec 28, 2008
  • 36 Answers
SOURCE: accidentally my aiwa 3 cd changer fall down and damaged
Same model is not in stock however new models in Aiwa and Sony are very nice in music.
Posted on Feb 10, 2009
  • 7 Answers
SOURCE: aiwa nsx-999 display and cd changer problems
replace lazer ever 2000 hours the display may have a dry joint on the 18 volt input ps the lazers are all the same in all the nsx moduls
Posted on Mar 23, 2010
I had a similar problem with my NSX-999. For CD, u need to clean the laser or buy a new cd-laser pickup KSS-210A.
For dim display, replace capacitor C107 and C108 in the mainboard if u know how or take to a repair shop and ask them to replace those two capacitors. It soled my problem
Posted on Jun 29, 2013
My aiwa cd disc rotating tray is not working i don,t know what's wrong with it
hi there i know wht is problem rotary changer systems like 5 disic or 3 dics chnager.i have 2 oprions for that 1 is,from cd chnager belt small belt between motor another also mechanism like small tears lack white if there not good oily enaugh,maybe stock with tooth,DO u hear motor when u tray chnage disc 1;2;3? if motor burn rotary change then never will work,Some times belts getting older in cd rotary changers.the gey slepery,like flashy,but i hope will help your problem.Regards,Emil
Sep 13, 2012 | Aiwa NSX-DS55 CD Shelf System
It is possible to connect a "AIWA NSX V70" as a
Use VIDEO/AUX instead. MIC is for the smaller input signal that a microphone would typically produce.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-NSX-V70-manual/id/1076ci461/t/2/
Use your PC soundcard controls to adjust the output to something useable (max?).
Apr 30, 2011 | Aiwa NSX-AJ300 CD Shelf System
How can I play my ipod on an Aiwa NSX-AJ310?
Simple!!! All you need is an 3.5mm to RCA cable, they're reasonably cheap.
Connect the RCA cable to the auxilliary inputs located to the back of your system.
Insert the 3.5mm jack into the headphone compartment of your ipod.
Turn on your system and then set the function to VIDEO/AUX. It'll be advisable to lower your volume, so that you may not cause any damage to your speakers!!
Play your ipod, make sure that all the volume is up.
Now, gradually turn up the volume on your AIWA system, and the music is supposed to be playing through your system. If not, refer to your manuals.
Hope this helps!!
JaHa
Nov 30, 2009 | Aiwa NSX-AJ310 Shelf System
SURROUD SOUND2
The video/aux connectors in the back are inputs. You plug the lines from your tv or auxillary components "output" in to them then you can listen to it on your stereo unit.
Jan 19, 2008 | Aiwa NSX-A115 Shelf System
SURROUND SOUND
does sterio system have aux in tv has rca outs use rca cable from tv outto aux in on sterio system ok the selct aux input on sterio turn it up
cheak tv settings for outout options ok
Power Problem? My DS55 red standby light blinks at me and won't turn on.
I agree with your diagnosis. If one channel quit and the unit now ocassionally won't output at all then the amp is going into protect. Have it serviced.
Sep 20, 2007 | Aiwa NSX-DS55 CD Shelf System
No sound from stereo
If you can hear a hiss then the spkrs and amp are OK. It sounds like you're not on whichever source you're wanting to hear or it is on mute. Make sure ther is no function enabled that turns the sound off or over-rides it (like a tape monitor or AUX in...).
Sep 09, 2007 | Aiwa NSX-DS55 CD Shelf System
Power cuts out
This problem happend to my sony system about a year ago. It was the amp that blew in mine because of the fan inside the system was not coming on when it should of. I found that when i had put my PC in the AUX jacks it blew the fan on me, so every time the volume got to 15 the system would just shut down and not come back on at all, or it would need time to cool down before it would start up again. Take it to a shop and get it looked at by someone that knows what there doing. Please dont try and do this yourself.
Aug 14, 2006 | Aiwa NSX-AJ205 CD Shelf System
Aiwa NSX-DS50 Shelf System Logo
83 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
