Question about Honda Garden
I have a troybilt mower with a honda 160 engine (#gcv160an5a) that will not start. I have cleaned the carb, replaced the spark plug, cleaned the air filter, new gas and oil. The spark plug is dry after trying to start. If I remove the air filter and pour gas directly into the carb the mower will start but only run a few seconds.
  • 407 Answers
You may have to replace the carb.But before you do.Check the the fuel line.There is a small screen in the carb,it may be clogged.Inside the tank is a small cylindrical filter,make sure it is good.Break the fuel line at the in line filter,to make sure gas is getting to there,if it is the problem is in the carb.
Posted on May 20, 2011
Honda hrx217 lawnmower will Not start why?
Might have shaken up dirt in the gas tank. Flush add clean gas with STABIL. Remove bowl from carb check for debris. Take a bread wrapper clean back plastic, use wire to clean out port up thru carb. Clean carb. Reassemble. Use clean air filter.
Jun 08, 2015 | Honda Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Troybilt push mower will not start
Might be bad gas. Empty tank refill with fresh gas with Stabile. Might have to remove carb bowl clean and reinstall. Flush out tank with a little gas before refilling, disconnect fuel line to flush.
Aug 24, 2012 | Troy Garden
Troy built mower honda 160 engine oil leak around governer shaft. no oil seal but shows one on parts breakdown. Can not find part number for shown seal.
Drain oil from mower until proper level. Remove spark plug and pull starter rope several times to blow out cylinder. Spray starter fluid in cylinder pull rope several times to clean out. Replace fouled plug with new spark plug. Remove air cleaner, ensure no oil present, replace filter as needed. Clean air filter box with carb cleaner. Install new air filter reattach filter cover. Prime engine, pull starter rope 1/2 way 4 times to help prime, then pull starter rope fully up to 10 times to start.
May 24, 2012 | Troy Garden
TROYBILT LAWN MOWER STARTS BUT DIES OUT
check for spark the spark could be weak
May 13, 2012 | Garden
First use of the Season, and it will not start...spark plug is tight, and air filter is clean...
BEFORE you go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers ---- http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Apr 05, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Honda push mower wont run right
I have the GVC160 motor....same problems....just found this info (see link),...and it turned out that Honda used a NGK spark plug that was defective,....I couldn't believe that is all it was...after changing the carb (new),...adjusting valves....etc.. I just went down and bought a new spark plug.....and it runs great!!
BEFORE go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers - http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Mar 24, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Sep 14, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Troybilt self-propelled mower - model 556 won't start
pipe from carb to engine broken. couldn't tell until covers & fuel tank removed. also part of deck holding engine came apart on mine. due to excessive vibration???
Apr 04, 2009 | Troy Garden
Garden Logo
513 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
