Question about Keurig B70 Coffee Maker
Machine says to descale.. But when we try to do so it won't even brew with the vinegar. When the "ready to brew " instructions come on and the brew buttion is pushed nothing happens. What;s next?
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
Vitale S coffee machine
Looks like you need to descale your machine. A good cleaner is CLR. Follow the instructions on the bottle. If you don't want to purchase that, use white vinegar. Fill up the reservoir and run a brew cycle after letting sit for 20 mins. Make sure u run clean water threw at least 3 cycles once done
Apr 28, 2013 | Coffee Makers & Espresso Machines
Keurig b60 won't dispense water
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar
into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
DO NOT USE A K-CUP
, just press the BREW Button. Pour the contents of
the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until"ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the
Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
water brew cycle. Pour the contents of the
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew
cycles if you notice any residual taste.
NOTE:
If "DE-SCALE" is still displayed after
completing the procedure, repeat the
descaling procedure above.
Dec 14, 2012 | Keurig B60 Coffee Maker
How to reset descale function on Capresso coffee maker
follow this steps and fix it. God bless you
    • 1 Unplug the coffee machine and remove the cup.
    • 2 Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
    • 3 Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
    • 4 Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
    • 5 Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
    • 6 Unplug the machine and dump the water into the sink.
    • 7 Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Oct 15, 2012 | Capresso Jura-Impressa C 9 One Touch...
How do you descale
Since you don't specify what type of machine you have, these directions are a bit general: Run a solution of white vinegar and water through the machine, turning it off 1/2 way through the cycle and let it sit for 20 min to 1 hr. Then turn it back on and let the rest of the solution brew through. Dump that, rinse off the carafe, brew basket or whatever parts are removeable, are run a brew cycle with just water Different makers will tell you different amounts of each to use, but I usually mix about 1/2 water and 1/2 vinegar, sometimes more vinegar. Don't use all vinegar, there's no reason to waste it, and less than 1/2 vinegar won't work very well. It depends on what kind of machine you''re descaling for the total amount of water/vinegar mix you would use... if it's a 4 c. Mr. Coffee, I do the whole pot. If it's a 12 cup coffee maker I use about 4or 5 cups of the mixture. Something like a Keurig is a bit more tedious - same general directions, but after rinsing the water holder, run clean water through the brewer several times before making coffee again.
Mar 31, 2012 | Coffee Makers & Espresso Machines
I have had my Kuerig coffee maker for over a year now which I believe means it's no longer under warranty. However, I paid quite a lot for it so I'd really like to see if I can have it repaired...
unfortunatly keurig treats any home model as throwaway once warrenty is up. They even do the same with mostcommercial models. By the sounds of your problems its time for a new one. sorry. try for a b145 or b150 they are a little more robust.
Sep 05, 2011 | Keurig Platinum B70 Coffee Maker
We have model # BKC800XL - it give us a message about "descale" not sure what that means and how to correct
Just like any coffee or espresso maker, descaling is a process that needs to be done periodically. If your location has hard water, you may need to descale more often than elsewhere, but it's nothing to worry about. It's just a chemical process that occurs as the result of mineral deposits from the water collecting on the elements inside the coffee maker. I'm sure that coffee manufacturers will sell you tablets for descaling, but I've always just used undiluted white vinegar as the reactant. To do this, I recommend: 1. Empty all of the water from the reservoir. 2. Fill with undiluted white vinegar. 3. For this type of coffee maker, brew as many cups as it takes to empty the reservoir, being sure to dump each cup in the sink as it finishes. 4. Once you've run through all of the vinegar from the reservoir, refill with water and run a few cycles to rinse. (You may want to leave the water to soak for a while to give the residual vinegar further time to clean off the minerals.) 5. Fill again with water and rinse. 6. Once you've emptied the reservoir a second time with the water, your machine should be adequately descaled and ready to brew coffee again!
Jun 17, 2011 | Keurig B60 Coffee Maker
Keurig B70 Coffee Maker Logo
1,495 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
