Question about Keurig B60 Coffee Maker
My Keurig is not filling my coffee cup.Instead it recirculates the heated water back into the reservoir.How can this be corrected?
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
The descale light keeps blinking, what should I do?
The 'Descale' light that turns on indicates that it is time to de-scale the machine.
Scale - or mineral deposits- form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water.
You will need :
  • Keurig coffee maker
  • 48 oz. white distilled vinegar
  • Water
  • Large ceramic cup
  • Sink
Instructions :
  • 1 Unplug the coffee machine and remove the cup.
  • 2 Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
  • 3 Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
  • 4 Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
  • 5 Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
  • Good luck ;)
    Dec 14, 2011 | Keurig Elite B40 Coffee Maker
    Won't pull water up into k cup, instead hot water flows back into the reservoir.
    heatman101
    Sep 13, 2011 | Keurig Platinum B70 Coffee Maker
    It does not do a full cup....I have gotten it to finish when starting over but now I cant get the water to run out at all...
    With the coffee maker unplugged and an empty cup in place, I filled the reservoir with filtered water and with a short length of flexible plastic tubing I blew in to the small hole in the bottom of the reservoir. I did this 4 or 5 times sucking some water in to the tube to force it through the system. When I had finished there were a lot of grounds in the cup and the next time I used the coffee maker it worked perfectly.
    Feb 17, 2011 | Keurig B30 Mini Coffee Maker
    Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
    heatman101
    Feb 02, 2011 | Keurig B70 Coffee Maker
    I have a Keurig B66, the reservoir water gets heated but then comes back into the water reservoir from the top vent tube. The water coming back into the reservoir is very hot; almost no water goes into the...
    Sorry to read about your issue.
    Try this first....
    you can contact Keurig at 1-866-901-2739 or Keurig.com
    You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
    The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
    Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
    Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
    If you taste vinegar..use more clean water, until the taste is ok.
    I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
    Dec 22, 2010 | Keurig B60 Coffee Maker
    The coffemaker won't brew and showed a descale message. What does that mean?
    Scale---or mineral deposits---form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water
    1.Unplug the coffee machine and remove the cup.
    2.Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
    3.Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
    4.Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
    5.Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
    6.Unplug the machine and dump the water into the sink.
    7.Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue
    Dec 10, 2010 | Keurig B70 Coffee Maker
    Keurig coffee maker sucks in water and spits it back into the reservoir instead of making a cup of coffee
    Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
    Keurig Coffee Brewer not making a full cup of Coffee
    heatman101
    l;]p]0
    Nov 17, 2010 | Keurig B100 Coffee Maker
    Keurig Platinum is clogged
    1. Power off machine.
    2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
    3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
    4. Reassemble KCup cradle and reinsert it back into coffee maker.
    5. Power on machine.
    6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
    7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
    8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
    9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
    10. Set Auto-OFF, if preferred.
    Mar 18, 2010 | Keurig Platinum B70 Coffee Maker
    Keurig B60 Coffee Maker Logo
    328 people viewed this question
    Top Keurig Coffee Makers & Espresso Machines Experts
    Lisa
    Lisa
    Jason
    Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
