Question about Refrigerators
I have a 532 sub zero thats been in garage that stay's cool and it has been unplugged for about 6 mnth .know the freezer door hits inside when i close .how do i fix this problem.i plugged it in figuring it will cure the problem.thanks
    Scholar:
  • 142 Answers
There is some adjusting you can do with the hinges. Each hinge has two or three bolts that you can loosen. But have a good look at the breaker strips. Those are the plastic strips around the front of the inside tank. Sometimes the styrofoam (between the outside and the inside "tanks") swells a little, and get in the way of the door when you close it. Does this help?
Posted on May 20, 2011
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Sub Zero side by side frig. side not cooling. Freezer works fine
There is a fan inside the freezer and possibly the fridge. It circulates the cold evenly throughout the unit. The fan may shut off with the door open so hold the door switch in to see if you hear the fan. It's behind the rear cover on the inside.
Sep 11, 2009 | Refrigerators
Left door open on Sub zero model 650
It went into self protection mode. Just leave it closed and when the compressor cools down enough, it will start. Once the ref starts to cool, the lights and such will come back on.
All of this assumes that no failure was caused by the long run times when the door was open
Sep 02, 2009 | Sub-Zero Bottom Freezer Refrigerator
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Model 532 freezer will not freeze
Check a Condenser, if it dirty and full of dust and lint - clean it with soft brush vacuum, it's behind the grill with Sub-Zero logo on it. Right hand side usually
Jul 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
Freezer side of 690 does not work (not even cool); refrigerator side works just fine.
Check the fan in the freezer department. It has to run when the door i closed. Sometimes the door switch is bad. This causes the freezer coils to ice up so the cold air does not go through the coil to cool the freezer. Unplug the power cord for 1 hour or two hours. Then plug the cord in and see if the freezer gets cold.
May 15, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 611/O not cooling
sorry but i do not have experience with hte sub-zero product line, I can reccomend to you thought that it is a very expensive piecce, and replacing it ( with another sub-zero) may prove to be a more costly option then the repair, Generally a Qualified subzeroe technician, (at least inmy area) is strictly a SubZero, specialist, so although you may pay a premium for the service it will be backed by the manufacture, and only 6-7 years old i cant imagine a problem that would justify replacing the unit.Althougth Im a Do-it-your self advocate, there are somethings that are generally best to leave to a professional opinion. This would be my reccomendation
Jan 17, 2009 | Sub-Zero 611 / O Bottom Freezer...
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
