Question about Directed Dei Valet 561r Remote Start/Keyless Entry
How to uninstall a remote starter valet 551R in 2000 jeep grand cherokee
3 Suggested Answers
  • 7 Answers
SOURCE: My Valet 551R is starting the engine by itself -
dnt mess with alarms if your not a pro you could really mess up system
Posted on Dec 27, 2009
  • 171 Answers
SOURCE: 2002 jeep grand cherokee with valet remote start.
Apart from the inginition wires ( you must check if there are 12 volts), the alarm needs to read the tach reading properly from the car to stay running. If the tach rate is not learned by the system, it will cut out almost immediately. You need to ensure that this tach wire is connected to the tach under the hood. When this has been connected, you need to ensure that the alarm learns the rate. This can be done automatically on some models or manually on others. Ensure that the appropariate wire is connected to your tach wire; it should work properly after that
Posted on Jan 02, 2010
Where is the valet switch located on a 1998/9 jeep grand cherokee? any pictures of this switch?
what makes you think there is one, reading the wrong
operators guide?
98 is gen 2 jeep, 99 is gen 3, so which is it? one or the other.
WJ or WK
i this switch is not a stock jeep part, nobody can guess unless
the custom alarm is stated and its model number, period.
there is no valet switch, sorry, not by jeep
why not post symtoms, and then work real issues, not phantoms.
some cars the valet is used in the , normal ignition key slot.
the 04 has a valet button under dash.
lots of rumor.
https://www.google.com/webhp?gws_rd=ssl#q=jeep+grand+cherokee++++valet+key+switch+location
what is the problem, car will only run for 3 seconds. that it
this is SKIM failure. (or other 6 reasons for ASD relay drop out)
post symptoms and win.
Mar 30, 2015 | Jeep Grand Cherokee Cars & Trucks
My keyless remote for my 2000 jeep grand cherokee wont unlock the
go to autozone and use the remote tester on the counter to make sure that the remote itself is functioning or not, could be a dead battery. On some vehicles it is possible to reset the keyless entry by turning the ignition switch from off to run (right before the starter activates) 3 times or so, if you try this and the door locks activate then press the lock button on your remotes. good luck
Jun 03, 2009 | 2001 Chevrolet Blazer
2000 Jeep grand cherokee limited remote start
higher end starters will have the lock/unlock/panic buttons built onto their fob. as for the seats... I dont know why it would interfere with your settings, but who knows... better to ask the seller of the remote start system.
Mar 18, 2009 | 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee remote starter keeps draining battery
A Simple Battery DRAW test w/ test light to Determine there is a Draw on Battery. With EVERYTHING OFF will determine that Something is Drawing Battery Down. Test light "Clamp on Neg" At Bat And the POKER AT CABLE, if it lights up you have a Draw
To Determine were it is, Pull Fuses out 1 by 1 Watching Light puting Fuse back in When you Pull a Fuse that turns the Test light off you found the Circuit that is Draining the Battery if it is A Circuit that Remote Starter is Connect to refer to Installer to Correct the Problem
NOTE TEST Light Connected this way and Electrical System in Tact Light WILL NOT BE LIT at ALL
Dont forget to keep doors closed during this Procedure
Jan 14, 2009 | 2000 Jeep Grand Cherokee
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
252 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
