Question about HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 all in one mechanism error print cartridge cradle cannot move
All Office
  • 58 Answers
SOURCE: Mechanism Error - Print Cradle won't move! - HP 5650
This "plastic strip" is called the "carriage encoder strip". This strip dictates the timing of the carriage assembly. If the end slots aren't broken, you can re-attach it. Otherwise, you'll need to replace it. They are about $10.
Posted on Jul 03, 2007
  • 57 Answers
SOURCE: hp psc 1210 all in one
Please follow the below given instructions to resolve the issue.
Please click on Start >> Programs >> HP >> HP Director.
Click on Settings >> Print Settings >> Printer Settings.
Click on Quality Tab at top of Printer Settings Window >> Set the Paper type as " Plain Paper " .
Click on Layout Tab at top of Printer Settings Window > Set the Paper size that you are using >> Click on Apply and then on OK.
Try Printing, that should resolve the issue that you are experiencing with.
If the issue still persists, try installing alternate drivers by following the below given instructions.
Installing the Alternate drivers:
1. Right click on My Computer, select Explore and then goto Control Panel, and then select Printer and Faxes.
2. Double-click the Add Printer icon. Click Next.
3. When prompted, choose Local, and then click Next.
4. In the Manufacturers list, choose HP.
5. In the Printer list, choose the HP Deskjet 870C printer, and then click Next.
6. Choose the port as parallel port, and then click Next.
7. The printer name should be listed as HP Deskjet 870C Printer.
8. Click No when the "Do you want your Windows based programs to use this printer as your default printer?" message appears. Then click Next.
9. Click No when the "Would you like to print a test page (recommended)" message appears. Then, click Finish.
Configure the alternate printer driver
1. Right-click the HP Deskjet 870C printer icon placed in the Printers window.
2. Select the Properties menu item.
3. Select the Details or Ports tab.
4. Select the DOT4_00x (where the "x" represents any digit) port from the Print to the Following Port list.
NOTE: The All-in-One model number should appear as part of the port destination.
5. Leave the printer identified as HP Deskjet 870C printer, and click the Apply button.
6. Close the Printer Properties window.
If Deskjet 870c is not listed, you may even try with Deskjet 990c or 550c
Hope that above information will work.
Regards,
Lawrence
Posted on Jan 06, 2008
rosener
  • 103 Answers
SOURCE: HP psc 1210 will not print
Please check the printer status at control panel printer properties if it is offline or ready. Restart your computer if necessary, you will notice all pending jobs will be printed as long as there is no problem with the connections of cables and drivers. Note: Do not cancel printing jobs in the middle of sending data mode to printer or queing instead you have to remove all papers on tray and wait for the error "paper out or empty" then there click Cancel. Hopes this helps.
Best regards,
Rosener Guyano
Posted on Feb 05, 2008
Junoon007
  • 1011 Answers
SOURCE: checl print cartridges light flashing
Hello sir,
It's not a problem... please check the advanced setting. Or better reinstall the Printer Driver. And in the tray bar u show the print status or some icon of printer. u just right click and check the all settings. After that it will be flashing means u just leave that bec. it not a problem at all. ok
Good luck
Don't forget to comment
Posted on Feb 24, 2008
SOURCE: won't print after changing print cartridge, check printer cartridge light comes on!
please install the printer hp 1200 series
Posted on May 02, 2009
I am unable to print, as the cartridge cradle does not move, even when I open the door. The letter E has been on the printer for hours.
Try turning it off then turning it back on. Sometimes something gets stuck in memory and you need to flash it to erase the issue. Also check the print queue on your computer to be sure something's not stuck in there as well.
Jun 15, 2011 | HP PSC 1210 All-In-One InkJet Printer
How to change or refill the ink
Turn the printer on.
Lift the lid that covers the print-head mechanism.
The print-heads will move to a position where the ink-cartridges can be removed.
Press down on a cartridge to "unlock" it from the carrier.
Lift it out.
Dec 20, 2010 | HP PSC 1210 All-In-One InkJet Printer
My printer doesnt print anymore error msg and will not turn off. Ive installed new print cartridges and no luck keep getting the error msg and wont print at all. I have a psc 1210 all in one
What is the error message?
Also, please consider the following:
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
Same or similar problem
Try to download the updated driver for this printer, I have the same problem and solved with the newest driver.
Jul 10, 2009 | HP PSC 1315 All-In-One InkJet Printer
It keeps saying that the the print cartridge cradle won't move
I have the same printer and mine has developed the same fault. Have cleaned it out, checked for obstructions, even updated the driver. Anyone have any other ideas as to a solution?
Mar 28, 2009 | HP PSC 1210 All-In-One InkJet Printer
Cradle jam after inserting ink cartridge, wont align
May-15-2008
in a HP-PSC-1210, replaced empty HP56 black-inkjet cartridge.
Afterward, printer gave error message AND unable to "dismount" the cartridge.
Finally discovered that an HP57 color-inkjet cartridge had accidentally been mounted/installed. A handyman relative was able to dismount the (wrong) cartridge.
Cradle did not actually jam, though printer would not print.
Apr 21, 2008 | HP Office Equipment & Supplies
Print cradle cannot move error
hi,
this seems to be a hardware problem..... anyway try this...
> unplug the powerchord
> open the rear access door, and check whether there is any paper jammed or any bit of paper or thread stuck inside.... if so remove it
> clean the rollers using a lint free cloth
> close the rear access door
> open the door so that you will get full access to the cartridges...
> move the cartridges to and fro for several times manually with your hand
> close the door
> plug the power chord
> try again to copy multiple pages
thanks and regards
agnel
Mar 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
97 people viewed this question
Seeker5211
Seeker5211
