Question about NetGear WNA1100 WirelessN 150 USB Adapter (WNA1100100ENS)
I need a driver of this device i'n clean and need instaler
  • 63 Answers
No Sound, Sound device not showing up on HP a1240n motherboard D33005
you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
cleaning your computer of dust using a fine air blower from a compressor making VERY sure that
there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD you might even remove the sound card to clean the socket dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jul 24, 2012 | HP Pavilion a1240n (EG136AA) PC Desktop
Tip
How to Free Download and Install/Update Windows Drivers with Clicks
If your computer's hardware started freaking out, freezing up or behaving in weird ways, don't lay blame at the feet of a mischievous gremlin. Instead, it's much more likely that your devices simply aren't rocking the most up-to-date and compatible drivers.
How can you fix this? A simple driver update might just fix your Windows hardware woes.
We know, Windows update will include most driver updates but not all updates are available via Windows update. So how can you quickly and completely update the outdated drivers for your Windows system?
Manually update one by one from Device Manager? I will not recommend this here since there is better tool that can help you do this. It is DriveTheLife which allows to download, install, update, backup, restore and uninstall hardware drivers with ease. It is totally free, safe and clean.
Just download it to have a try if needed!
DriveTheLifeWindows Drivers Update download Backup Restore Install...
on Mar 04, 2015 | Computers & Internet
Driver for iphone4 code 28
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 28 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue. Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Error Code 28 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Jan 08, 2012 | Microsoft XP Computers & Internet
I want Ezonics usb webcam driver
Please be informed that any Driver software depends upon the hardware make and Operating System. So, you need to know all these information's to do get going.
Please find the Driver software's of your webcam inside the installation disk provided with the System at the time of purchase. In case if you do not posses the same then you need to download the driver software from the web. As you have not mentioned your Webcam make and Operating System you are using, I am unable to give you the direct download link. However you can download the same by visiting the website of the company that manufactured the Webcam.
Even here you need to be careful to download the correct software for your PC. You need to be exact with the Webcam Model number and the OS that you are using.
After you have downloaded the driver, to install just plug in the webcam on to your PC and then Double click on the driver setup.exe file and go on clicking 'Next' until you get the 'Finish' option and restart the PC.
Sep 27, 2011 | Ezonics EZCam Webcam
My pc says no audio output device installed,but in device manager it says its working properly and the drivers are up to date
Well it is possible that the audio driver installed is not the one compatible with you computer board. Try downloading the specific driver needed for your computer's official website. This should solve your problem.
Sep 06, 2011 | Computers & Internet
HI, i have a IBM thinkcentre S50 8086-21G and after resinstall on my hard drive the XP SP2 version , i don't have access about the USB connector and can you help me about this? i don't find the...
What exactly are you trying to connect to the computer via usb? If your talking about generic devices such as usb mice and keyboard then you will need to reinstall windows again. Devices like these use a generic usb driver that is installed during windows xp installation. There isn't really anyway to install this driver that I am aware of other then a clean install of windows
You could attempt to repair the windows system files, but I can't guarantee it will help.
You will need a windows xp disc. -Insert the disc. -Press the "Start" button -Click on run -Type "cmd" and press enter -Type "sfc /SCANNOW" and press enter
This will check for problems with your system files. Hope this helps
Clean install of windows (Delete all partitions and re install fresh) would be the easiest way to fix the driver problem. I did also find this article on how to manually install the usb driver. Best of luck http://support.microsoft.com/kb/329632
Jul 10, 2011 | Computers & Internet
I don't have audio and can't install the driver
Make sure that audio is enabled in the BIOS. Check to see if it displayed in the device manager and that it is enabled, as this will prevent you from installing the driver. It is also possible that the device is defective and you will need to replace it. I hope this helped. Good luck and have a fantastic day.
Jun 24, 2011 | Sony VAIO PCV-W1 PC Desktop
The drivers for this device are not installed. (Code 28) There is no driver selected for the device information set or element.
Resolution
    • Remove or reconfigure the newly installed device.
    • Roll back the driver to the version prior to your update.
    • Use System Restore to undo recent Device Manager changes.
Applies To The Code 28 error could apply to any hardware device in Device Manager but most Code 28 errors seem to affect USB devices and sound cards.
Any of Microsoft's operating systems could experience a Code 28 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 28 Issues in Device Manager? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum. Be sure to let us know that the exact error you're receiving is the Code 28 error in Device Manager. Also, please let us know what steps, if any, you've already taken to try to fix the problem.
----------------------------------------------let me know if this helps--------------------------------------------
Jun 20, 2011 | Computers & Internet
I install Activated Windows 7 and I know that it ha no sound so I want to install the audio and sound of the computer, if you can help me please solve my problem. thanks
Installing Audio driver in windows 7 should not be a problem. If windows is not able to install the drivers automatically, you can update the drivers using the internet. Here's how you do it.
Surely, windows 7 has detected your device and it should appear in device manager.
Go to Device Manager Check for the Audio Device (you will see this with an error) Right click on it and click on Update Driver then choose update driver automatically.
You should be connected to the internet when doing this as win7 will look for a compatible driver for your device. If this fails, you have to go to your PC or device manufacturer's website to look for a compatible driver.
Apr 20, 2011 | Computers & Internet
Error 39 no driver found
I suspect you need to perform a little Registry surgery. Sounds suspiciously like an upper and lower filter and /or driver problem. See link below for instructions
http://support.microsoft.com/kb/314060
Although other things may cause your problem, it definitely will not hurt to install a clean driver.
Note: Registry edit is needed to properly re-install driver
Jun 17, 2008 | Computers & Internet
NetGear WNA1100 WirelessN 150 USB Adapter (WNA1100100ENS) Logo
118 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
