Question about Canon DR-2050C Path-Through Scanner
Canon dr 2050c
The computer software is installed, the scanner is plugged in and connected to the laptop. I cannot get the scanning to begin
I want the driver for canon dr-2050c
Posted on Nov 12, 2008
DR-6080 not recognised after reloading Windows 7 (32-bit) on laptop. Re-installed latest driver (says Win7 supported) successfully but still won't work, Anything?
Disconnect the scanner from the computer. Uninstall driver software, shut down and restart the Comp. Reinstall the driver. (http://software.canon-europe.com/software/0036991.asp?model= ). connect the scanner and the system will report USB device plugged in. This should work.
S. Mohan. Chennai, India
Dec 02, 2011 | Canon DR-6080 Path-Through Scanner
Installed driver twice for Canon DR-2050c. Still
Pls run checkdisc/scandisk on your Comp. Your OS may be corrupted. Just to verify try scanning by connecting to a formatted newly loaded OS Computer.
S. Mohan
Sep 09, 2009 | Canon DR-2580C Path-Through Scanner
Canon 2050c scanner replaced rollers still scanning 1 page per minute
please check the resolution it may happen higher the resoulation time take for scanning is more.
if problem persists then please change photo IC
Aug 19, 2009 | Canon DR-2050C Path-Through Scanner
No Device Found?
Ive had this problem as well, and usually restarting the computer fixes the issue. im guessing that you have already tried that, but just incase ill suggest it. You can also go into device manager and remove it, and then use the software disk, reinstall.
Feb 07, 2009 | Canon DR-2050C Path-Through Scanner
DR-2050C Scanner all sheets feed thru only one scans
Do you get an error message after the first scanned image? If not, check your software settings to see if you have the option of single page /multipage scanning. Some software lets the customer choose a single page scan when the SCAN button is pressed.
Check the "Feed Select Lever" to make sure it is in mutifeed position. If not, it will grab all of the docs at once.
Jul 05, 2008 | Canon DR-2050C Path-Through Scanner
DR 2050C
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Dec 19, 2007 | Canon DR-2050C Path-Through Scanner
Canon 2050C scanner
In the software, select 'multipage' option. (Check this box). The output will be collated and provided to you as a single file.
S. Mohan
Feb 08, 2007 | Canon DR-2050C Path-Through Scanner
Canon DR-2050C Path-Through Scanner Logo
352 people viewed this question
old marine
old marine
