Question about Belkin (F5D5231-4) Router
My internet connection became slower after i got xfinity internet and belking router.Can a cause of the problem be a conflict between belkins firewall and Mccafee firewall that i have for a long time.If it can then how can i fix it?
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Temporarily disable your firewall and optimize bother browser and Internet using some reliable optimizer such as Reginout. Thanks
Posted on Jun 24, 2011
  • 63 Answers
It could be a conflict.. but the main thing is there really is no reason to have a 3rd party firewall installed on windows, it has it's own firewall, then you have the firewall built in to the router, all mcafee's firewall is doing for you is taking up resources and potentially causing conflicts.
I would remove that firewall and see if that helps, if not, reset the router to factory defaults (there should be a reset button on the router) and configure it again, possible that it was not set up correctly or got corrupted somehow.
With the introduction of Windows 98 SE Service Pack 2, there is no reason to have another firewall installed.
Hope this helps
Posted on May 20, 2011
My laptop wont log on to belkin
Sir,
Check your IP Address, Maybe its conflict with other device.
My advice to turn it automatically.
Or
Installing your Belkin router is still possible even without using its Setup CD. You can set up your router manually through the web-based setup page of the router.
Perform the steps below to set up your Belkin router through the web-based setup page.
NOTE: images may vary depending on the router model or computer you are using.
Power cycling the modem and router
Step 1:
Unplug the modem and router from the power source.
Step 2:
Connect the modem to the WAN or Internet port of the router.
Step 3:
Power ON your modem first, then your router by plugging them back to the power source.
Manually setting up your router
Step 1:
Connect the computer to one (1) of the Ethernet ports of the router.
Step 2:
Launch a web browser and enter "192.168.2.1" in the address bar.
Step 3:
Click Login.
Step 4:
Leave the Password field blank and click Submit.
Step 5:
Under Internet WAN, click Connection Type.
Step 6:
Select your Connection Type, then click Next.
NOTE: If you don't know your Connection Type, contact your Internet Service Provider (ISP). To know how to set up your router according your ISP, refer to the links below:
Cable Internet Service
PPPoE / DSL
Static IP Account
Step 7:
Enter the details provided by your ISP and click Image.
You should now be able to connect to the Internet. To verify, Internet Status on the upper right corner should read Connected.
You can also launch a web browser and go to your favorite website or try visiting the Belkin Site for more information and support on your devices.
as mention On official Belkin website vedio for Belking Online Support:
Setting up the Belkin router using an iOS device Video
Belkin
Or
In case you still need assistance then follow us for Belkin Tech Support on:Belkin Support
Mar 07, 2014 | Belkin N Wireless Modem-Router F5D8633au4A
I had to reset my router because I forgot my security key. Now the wireless isn't working. The light is off and I can't connect to it with my laptops. What happened and how can I fix it?
It is possible that since your reset your router that the settings is more likely to be reset as well then you will have to connect using an ethernet cable direcly from the lptop to your router to turn on the wireless capability of your Belkin router.
You will need to get your router's Default gateway to get in the router and turne the wireless capability on it. Most probobly the IP address of your Belking would be 192.168.2.1 type this in IE on the address bar then press enter this should lead you into the router "Belkin" make sure that your are connected using ethernet from the laptop to your Belking router to be able to do this.
Feb 21, 2011 | Belkin (F6D42304) Wireless Router
Windows 7 upgrade, Belkin wireless router. Sa...
I RECOMMEND YOU TO UPDATE THE FIRMWARE OF YOUR ROUTER. Download the firmware from belking support site.
May 20, 2010 | Belkin F5D8236-4 Router
Belkin Router Signal Weak
Wireless configurations are tempermental over larger distances. Some routers do have the ability to increase the signal strength to over come this, but a good location is key.
The more obsticals in the way the slower the connection will become. Closed doors, being buried under books, underneath desks, can all cause the signal to come through a slower speeds to compensate.
Make sure your router is in an elevated location to help with a less blocked signal.
Are you using a Wireless-N adapter on your computer? If not, you might need an extender because Wireless-G does not have the same range as -N.
With the model number of your Belkin router I might be able to assist more.
Jan 20, 2010 | Linksys Wireless-G Broadband Router
Flashing amber modem light on belking n wireless router
Actually there is no problem with the Modem
First Get the following Information from your ISP
1 ) The Connection Type
2 ) If it is PPPoE then Get the user name and Password
Step 1 : Connect Modem - Router - Computer (Wired)
Step 2 : Open RSP By typing 192.168.2.1 on the Address Bar of the internet explorer
Step 3 : On the Left Side Under Internet WAN Click
Connection type
Step 4 : Leave the Password Blank and click Submit
Step 5 : Select the connection type as given by the ISP
Step 6 : Click Next
Step 7 : Type Username And Password for PPPoE ,Click Apply Changes
Step 8 : There is no need to type Any Host Name for dynamic Click Apply Changes
Step 9 : If it is A Cable connection then
Step 10 : On the left side Under Internet WAN Click MAC Address
Step 11 : Click Clone
Step 12 : Click Apply Changes
Step 13 : Restart the Router
Step 14 : Check the Internet Status
Jan 11, 2010 | Belkin Wireless-N Wireless Router with...
COMPUTER WONT LOG ON JUST INSTALLED A BELKIN WIRELESS ROUTER
software conflict check the Operating System you are using and see whether the drivers of the belking wireless router is compactible with the OS if not download a siutable driver for your router to work
PS. what ever you do you need to re-install the OS
Dec 30, 2008 | Computers & Internet
Hi, I have a desktop and a wireless router. The desktop was connected to the internet via a Belkin USB wireless adaptor but it has suddenly stopped and does not pick up any signal. I have uninstalled and...
Belkin products are notorious for breaking down at a high rate. If you wanted to rule out your computer as the culprit, you could install the belking adapter on your laptop (disable the built-in one) and see if it still works. I would also suggest going here:
http://www.belkin.com/support/
and typing in your product model # and downloading the latest firmware/software for it. As always, restart your computer.
Jun 10, 2008 | Belkin Computers & Internet
My Belkin Software!
Try the Belkin WEB site or Google the driver
May 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless Internet Connection
Are the wireless router connected to a network?
Oct 18, 2007 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin (F5D5231-4) Router Logo
175 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
