Question about GE Microwave Ovens
All of the control buttons on my microwave/hood (except 2) are non-responsive. Our cleaner was here the day before we noticed it. She has cleaned for us for two years and there was not a problem until now. If the controls somehow got wet, is there any way of resetting them, drying them our or repairing them? It is going to be a real chore to get it out.
    Scholar:
  • 142 Answers
Possibly some water or cleaning liquid got inside the touch panel. The touch panel has several layers of plastic material. If water got in between it would eventually evaporate. You could speed it up by carefully warm it with a hair dryer (on low). If cleanser got in the control it could cause parmenent paths for electricity to flow in which case you would need to replace the touch pad. One thing you could try (if you are really handy) you could take the touch pad out and soak it in distilled water (it is no good anyway) and then dry it. Good luck.
Posted on May 20, 2011
Microwave Advantium Built In has power but panel has no control Exclamation icon is shown.
please make this test and fix it. God bless you
  1. Controller is confused A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switches This can result in the controller thinking the door is open and ignoring you.
  3. Cleaning Cleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Dec 17, 2013 | Microwave Ovens
Ge jnm1541sn1ss
please do these test and fix it. God bless you
Dec 12, 2013 | Microwave Ovens
Kenmore Elite Microwave model 88523 has failed 2 times with an error code of TE. Sears fails to accept responsibility for the manufacture of a defective product, instead put the blame on me for not p
make this test . God bless you
  4. main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  5. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Microwave showing FO1 when turn on all switches
this code normally means defective keypads. test it and replace if necessary, follow this steps . God bless you
Dec 10, 2013 | Miele H187MBALU Convection/Microwave Oven
Whirlpool MWD308
follow this steps and fix it. God bless you
Nov 26, 2013 | Microwave Ovens
Blinking electronic display on microwave
see the cause and proceed according. God bless you
but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 17, 2012 | Sharp Half Pint Microwave Oven
Display show SE from samsung microwave range hood
The keypad has a short in the membrane, which means the keypad control board will probably need to be replaced.
May 05, 2012 | Samsung SMH8165STE Microwave Oven
Dead unit
first WAIT sometimes the control board gets wet , it may dry out in a few days and will work again . but while you wait un plug it . a live board thats wet might not last long if powered up ...... if still no good see if the light works . if it does the board is bad if the lights dead too , then theres a fuse inside that may have blown
Jun 13, 2008 | GE JVM1640 Microwave Oven
GE Spacemaker XL Microwave
Sounds like a failing or wet keypad or *maybe* the controller.
Is it possible that some spray cleaner accidentally got into the controls?
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
This can usually be fixed economically, but please look over this response and then I'd be happy to help further.
Please rely back to this thread if possible when leaving replies.
Dec 02, 2007 | Microwave Ovens
Panasonic nn-k354 microwave
Is it possible that some spray cleaner got into the controls?
I always recommend that users spray cleaner on a soft cloth then wipe the control panel.
I always recommend non-ammonia cleaners since they can crack and damage plastic.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 05, 2007 | Microwave Ovens
Microwave Ovens Logo
52 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
