3 inches of the top of the screen looks like its flipped over onto the picture
  • 4,234 Answers
If this is a standard set, the problem is a bad capacitor in teh vertical circuit. If you can post the make and model of the set, I'll list the circuit designation and part.
Dan
Posted on Aug 14, 2008
My panasonic PT-51SX60A has a 2 inch picture loss
tv looks fine then I get just a line in middle and nothing else
Jul 24, 2010 | Panasonic PT-51SX60 51" Rear Projection...
I have a Philips TV model: 27pt9015d. at the top of the screen several horizontal lines have appeared. it looks like the top inch is being cut off and then flipped back. that is - when credits are...
sounds like the vertical adjustment has spanned beyond the screen, causing it to jump up and then upside down. after the cover is removed look for vertical adjustment and with a non-conductive screwdriver, adjust it a little bit either way to see if it fixes it, if it doesn't fix it, then look again for the right one.
Jun 18, 2008 | Philips Televison & Video
Screen does not lighy
If you look very closely, is there an extremely dark picture, or a solid black screen? If it's an extremely dark picture, you just need a new backlight. If it's a black screen, you either have a bad connection (broken, shorted or unplugged cable), or need a new LCD. Let me know, and we'll go from there.
Sep 05, 2007 | Cyberhome CH-LDV 712 Portable DVD Player
My 52 inch rca hdtv comes on but it looks like the screen is bowed and the colour is off.do you know of any solutions to this problem.
My rca 52 inch hdtv picture looks bowed on the top and bottom of screen. And everything looks like it has a red shadow behind it.
May 12, 2010 | Televison & Video
Lines across my tv where the picture is reversed
You have bad capacitors in the vertical deflection. And you will have to resolder the vertical IC as well. Replace the caps in the area of the vertical IC. Find a TV tech or hobbiest to do this!
Apr 14, 2010 | iLO IWT3206 TV
Red lines across the screen and bleeding around corners
This is your LVDS cable. You could replace it yourself and find a replacement online.
1) flip the LCD screen down onto a soft blanket
2) remove all 30 - 40 screws on the back
3) pop the back off
4) look for the LVDS wire, it runs from the top of the LCD screen to under the power unit and into the Main Board.
Jan 05, 2010 | Vizio VW42LF 42 in. LCD HDTV
Top 3 inches of screen have horizontally flipped
that Good , you are a n electronics technician , check capacitors and resistors in vertical circuits ,
Sep 24, 2009 | Philips 27PT9015D 27" TV
How do i remove the cover of a Gateway MFATXPNT NMZ 500SE
I found this:
"Facing front of computer you need to remove the left side cover. cover release is on top of the computer in center of side panel. Press in on button and p[ull top of side cover away."
Don't know if it's useful. If not let me know and I'll keep looking.
Mar 16, 2009 | Gateway Computers & Internet
TOP OF PICTURE FLIPS DOWN VS-50605
try hitting the side of your set to see if you can get it to jump out of place. If your can get if to fail by doing this your convergence amps have bad solder joints.
Aug 29, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Dropped TV
Hi craigaloid your problem is the flourecent lamp on that side it could be broken after it fall have a tech look at your tv for repairs.good luck
Apr 26, 2007 | Samsung TX-R3080WH 30" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
