Question about Onkyo Audio Players & Recorders
Onkio receiver i have a Ht-R510 onkio receiver that shuts down immediately after being turned on. The amp. protection system has been activated is what the manual tells me. How can I fix my problem?
  • Anonymous Jan 07, 2009
    Different model - same problem.
  • clifton52 Feb 05, 2009
    I have the same problem and a ohm meter what is the test procedure
I have a 502 same problem i see 12 transistors attached to the heat sink getting around 5 ohms but what legs should i be reading from ,their marked b,c,e and should i also be looking for continuity between legs or not.. the 3 legs and the main bolt.. seperatly ? ?
Posted on Jun 20, 2009
  • 4,234 Answers
The usual cause of this is shorted output transistors. If you have experience with repairs and can solder, you should be able to repair this yourself. Open up the unit and look for the 3-legged parts attached to the heat sink. These are the output transistors. Post here the markings on those parts so I can give you the entire part number. In order to determine the bad ones, you should have an ohmmeter or diode checker. Post the parts markings and we'll continue from there.
Dan
Posted on Aug 14, 2008
After turned on the power, the unit shuts down immidietly
There is a problem in either the power supply or amplifier output stages. The unit is programmed to shut down in such an event to protect other circuitry.
Using a schematic see if you can isolate the power going to the output stages. If unit stays on then the anomaly is in power amp stages. If it still shuts off problemo is in power supply - check diodes and capacitors.
Mar 12, 2015 | Onkyo Ht-r510 5.1 Channel 100 Watt Av...
My onkyo ht-r590 goes on then shuts off right away.
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Oct 01, 2014 | Onkyo HT-R590 7.1-Channel 3-D Ready Home...
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
Onkio amp popped and smoked and won't turn on
check the back and there should be a fuse holder and check the fuse. Likely that your fuse is blown.
Otherwise you might have caused a short in your speaker which will do more damage but check the fuse first.
Oct 28, 2013 | Onkyo Onkio Audio Video Control Receiver...
My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Dec 04, 2009 | Onkyo TX-SR501 Receiver
No sound when dvd input is selected on onkio tx-ds696
Make sure your DVD setting is looking at the right audio inputs. Usually there is a menu option or a button to toggle from analog or digital input. Usually when no-sound but video ok, you have the wrong input-type selected. If you are using 2 RCS's (red/white) then you want ANALOG input mode. If you are usung a single RCA (orange) or a fiber optic input for audio, you want DIGITAL input selected. If digital os selected, make sure you plug into the correct digital input to hear. If it does not work at first, mofe the jack/fiber around into the different inputs untill you hear sound, then you will know which port is associated with the DVD setting. Unless it is self evident feom the menu.
Jun 12, 2009 | Onkyo TX-DS696 Receiver
Sounds is lower than it should be, possible short.
Having read the problem report two or three times, it appears that you're running ~three~ cables from your cable receiver to the home theater system - orange, and red&white.
Often, when you can hear a low-level signal on an input, it's due to 'leakage' from another input, and it's my hunch that the cable receiver is sending audio through the red and white (analogue) connections, which you've plugged to the main sat/cable receiver inputs.
To confirm this, I'd be interested to know if, when you unplug the red and white connectors from the back of the Onkyo, the quiet signal completely disappears.
If that's the case, I would suggest either going into the cable receiver's cofiguration to see if 'digital audio out' is set (if such is possible) or switching the input to 'cable/satellite'...
Hope this brings you closer to the root of the problem!
Feb 07, 2009 | Onkyo HT-S5100 Theater System
Onkio receiver
The output transistors should be replaced in pairs. Also, It may not be just the output transistors that are defective. If you have no experience with these types of repairs, I would suggest that you bring the unit to a service shop. The outputs will run about $15-$25 per pair.
Dan
Aug 29, 2008 | Onkyo TX-SR601 Receiver
No sound when first turned on.
i have an amplifier ONKIO too and my generation is older than yours but i'm the same probleme and it's normal if you use this amplifier to your speakers. the internal switch must be heat to give a normal sound without distorsion. it's the principal problem of the onkio amplifier but after the quality of thr sound is great
so take the time and be patient now you know you have to start on your amplifier 5mn before use :)
Jan 18, 2008 | Onkyo TX-SR502 Receiver
HT-R510 home theater system
If bought new return immediately for replacement. The amp section is no good and cannot be reset - needs repair. but you are under WARRANTY - use it.
Sep 06, 2017 | Onkyo HT-S490 System
251 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
