Question about Maytag PAV2300 Top Load Washer
Spin cycle is not emptying completely the basin. clothes are relatively wet.
    Scholar:
  • 142 Answers
Put it in spin (empty) with the lid open and push the lid switch. If you see that it agitates while it is going into spin, that means that the "catch" inside the transmission is broke. The "catch" is supposed to lock the mechanism to the spin basket while in spin. The only thing you can do is replace the transmission or buy a new machine.
Posted on May 20, 2011
New washer- WTW5000DW0 / C43742143 clothes not spinning
are the clothes very very wet ? is the machine emptying properly? you could check that the pump isn't blocked or partially jambed I'd start at the pump first, barring that it could be the main program controler
Nov 30, 2014 | Washing Machines
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Spin cycle does not work properly
If clothes are still wet this mean there is still water in the drum and the pressure switch is not switch in empty position. The fault should be sought in the draining phase. Could be: drain pump ....
Dado
Apr 13, 2014 | Electrolux EW1200i Front Load Washer /...
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
My daughter in put a load of wet clothes (not completely finished spin cycle). Now dryer doesn't heat the clothes but seems to have all other functions.
Try running the dryer empty to see if the elements are heating. With the weight of wet clothes it is possible to trip the overloads.
Jan 03, 2010 | Dryers
The spin cycle spins very slowly and the clothes come out extremely wet (drippping wet). How do I troubleshoot this problem?
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jul 14, 2009 | GE Energy Star WCVH6260F Front Load Washer
Machine won't rinse or spin properly..also stinks!
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 08, 2009 | Maytag HAV2557 Top Load Washer
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Clothes are still water logged after cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
From Repairclinic
Oct 24, 2008 | LG WM1814CW Front Load Washer
Maytag PAV2300 Top Load Washer Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
