Question about MTX X Thunder 300XD Car Amp
I have a MTX 300XD...it just stopped working. I tightened everything up and it still doesn't work. the red light is on but there is a green flash and when it flashes it makes a noise that I can hear through my speakers. It works fine if I hook it up in different car. I don't know what to do? help!
  • 407 Answers
What is the electrical system in the different car like?You may need to get a secondary battery for that amp.Also ceck your in line fuse,it may need to be larger.Sounds to me like you either do not have enough power,or a ground is not connected.
Posted on May 20, 2011
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
It has stopped workin and the red light is flashing.Is this a code and if so how do you read it
The red light is a power protection circuit designed to shut the amplifier down due to an overload or wiring problem. If the amp was playing then shut off, my guess is a problem with the speakers or the speaker wiring. Some amplifiers are only stable to a certain load. For example, most car audio speakers are 4 ohms which is the resistance placed upon your amplifier to produce a certain volume of sound. If you bridge two 4 ohm speakers together in parallel, you cut the resistance in half, thus increasing the amount of power (and volume) to your speakers. This also creates more heat and could, in effect, shut your amplifier down. I would find out how the speakers are wired to determine the resistance of the load your amplifier is pushing. Also check the grounding.
May 26, 2011 | MTX X Thunder 300XD Car Amp
I just got a mtx thunder 6152 amp got it all hooked up its working but red light is on, should it be red or green?
http://www.mtx.com/caraudio/archive/NDM185.pdf .... go to this link for more help, it is the owners manual
Apr 24, 2010 | MTX Thunder 6152 Car Audio Amplifier
Everything works fine but my amp light is red.
if its not coming on it usually means you have a bad ground if it works for a little while then does it then its over heating and you will need to get a fan
May 01, 2009 | MTX Terminator TN400/4 Car Audio Amplifier
My neg and pos got barred in my truck. I checked all the wiring and fuses, all seemed well, the amp boots up but i cant get the protection light to turn off
sorry to say that you proably fried the amp. there is a way to check, find the air vent on the amp, and smell it, if you smell a burnt smell, its fried. you might get lucky and the amp might be under warrenty
May 01, 2009 | MTX X Thunder 300XD Car Amp
My red light on my amp is on and wont go out
Unfortunately I think you need to get it repaired or replaced .When a protection light will not turn off it is generally caused by an internal short and needs one or more replacement parts for it to come alive again.
-Dynami
Apr 03, 2009 | Insignia 600W Bridgeable Amplifier with...
Apx stopped working, MTX 702x
maybe the audio amplifiers Ic´s damaged or the power fet
Mar 06, 2009 | MTX X Thunder 702X Car Audio Amplifier
I need help hooking this up
"is the got two wires in the ground and remote turn on wie"
Can you be more specific about the wiring...where the two wires are connected to and where they come from, and I'll try to help you.
Mar 29, 2008 | MTX Thunder 895 Car Audio Amplifier
Singer futura CE-100 4 blinking reds lights
This error indictaes that the upper thread is broken. If it is not the sensor is telling the computer the thread is broken. Try tightening the upper thread tension some and rethread the upper thread.
Dec 23, 2007 | Singer CE-100 Futura Computerized Sewing...
MTX X Thunder 300XD Car Amp Logo
218 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
