Washer will go into spin cycle automatically after it is filled for rinse
  • john_spillum May 20, 2011
    GE WBSE2090 top loading at least 4 years old. Here when I bought the house. Everything works fine except you have to manually turn it to spin only and push start after it fills with rinse water.
    It must not because the clothes are sill on the outside portion of the drum like it just finished it's last spin. Hmm. Never thought of that before.
    Scholar:
  • 142 Answers
To answer this question I would need to know what brand washer you have, and is it a top or front loader; there are just too many potential senarios I could think of.
Posted on May 20, 2011
  • Henry Leunissen May 20, 2011
    So if I understand you correctly the machine goes through the cycle normally but it stops after it filled for the last rinse. Does it actually agitate (rinse) and then stop before it goes into the final spin?
Washer fills on wash won't fill on rinse. Does on old washer and new washer. Checked and plumber said not the plumbing. Help PLEASE
It seems that you are out of cycle; meaning you are washing on rinse phase and the you are not getting water on rinse because you are at the end of the cycle. Try this; set the washer to the end of the rinse cycle, let it spin and stop. then wait 1/2 hour then start a wash you will be at the beginning of a new wash cycle..
Nov 10, 2016 | Washing Machines
Washer fills with water during spin cycle
Go to repairclinic.com and have model number ready. They have videos how to check it
Mar 02, 2015 | Samsung WA422PRHDWR 4.2 cu. ft Large...
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Washer when set turns on and fills and agitates. But will not move to next cycle automatically. I can manually move the dial to rinse / spin and it works properly. But again won't move to final spin...
From the way you discribe it, sounds like you have a bad timer.If you decide to fix it yourself be sure to mark the wires before removing the timer.
Apr 06, 2011 | GE Washing Machines
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer won't advance from cycle to cycle
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
Nov 16, 2008 | Danby DDW1805W Designer Series...
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
