Question about Keurig Platinum B70 Coffee Maker
The water resivoir is full, but it wont brew coffee
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on May 20, 2011
Why cant I get a full cup of coffee
Brewing a Partial Cup
If the brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer needs to be descaled. Please refer to the descaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup pack.
Jul 27, 2014 | Keurig B60 Coffee Maker
I am trying to use by Keurig b70 and when it says its brewing the water just runs back in to the resivoir. Nothing comes out in to the cup. Why?
heatman101
Aug 15, 2011 | Keurig B70 Coffee Maker
Hamilton beach brew station leaks water all over when filling the coffee maker - no problem once the coffee is brewed...why is the water leaking???
chances are, you're filling the machine up with too much water. look at the water resivoir and see if there's a hole somewhere toward the top or a marking indicating the water limit.
-Bam-
Grape Jelly
May 06, 2011 | Hamilton Beach BrewStation 47214 Coffee...
All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine, dumped rinsed and refilled the water resivoir. Still nothing good and no coffee. I...
All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine,All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine, dumped rinsed and refilled the water resivoir. Still nothing good and no coffee. I have since put the machine away and have stopped trying to use it. Any help that you might be able to give would be greatly appreciated. Thank you Tandie Grant
Oct 26, 2010 | Braun Tassimo Espresso Machine/Coffee...
MY b60 all of a sudden won't fill a full cup when it brews. I descaled it and it works just fine and fills the cup with water and no kcup in place. When I brew with the kcup it only half fills.what can I...
When I descaled my b60 I also used a paper clip to clean out a possibe clog in the little bottom drainage tube. The help I received suggested I also use the paper clip to check the top tube which I didn't know about. I did this and now it works fine...thanks for your help.
Dec 30, 2009 | Keurig B60 Coffee Maker
Not brewing full pots of coffee
Check the in line water fliter. It may need to be changed.
You can try this also.
Put the brew basket in place with no coffee in it, put an empty decanter under the basket. take a full decanter and pour it in the water fill screen at the top of the unit. When the wtaer stops dripping and the unit is back up to temp, try a full brew cycle.
If it works OK, it just got low on water in the tank
Could be caused by a plugged up filter or lime scale build up.
Dec 28, 2009 | Bloomfield 8572 Coffee Maker
Coffeemaker
The Bunn coffee machine has an internal tank used for holding approx three potfulls of water at just below brewing temperature. When you add water for a potful, the thermostat senses cold water and starts the brew heater. The water level inside the tank comes up and goes through the sprayhead. This "surge" of water, that you call drips is normal. The hot water stratifies to the top of the tank, just like an electric water tank in a house. The internal pot heater kicks in and boils the water already in the tank, raising the water level in the siphon pipe to the sprayhead until the reservoir under the add water opening is empty.
Sep 15, 2007 | Bunn NHB Coffee Maker
Does not brew a full pot anymore.
I had the exact same problem with my machine making 1 cup at a time.
Here is the solution:
1. make solution of 1 part vinegar & 2 parts water.
2. pour solution into resivoir and set for 2 hours
3. run solution through machine (yes, you will have to stand there and keep pushing the buttons).
4. take same solution (now very hot) and run it through machine 5 or 6 times
5. make fresh solution and continue process
Sep 01, 2007 | Cuisinart DGB-600 Coffee Maker
Wont brew a full pot
5. make fresh solution and continue process until machine runs full cycle.
May 27, 2007 | Cuisinart DGB-600 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
99 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
