Question about Fujitsu Siemens LifeBook N6110 Notebook
Need to remove a keyboard from a Fujitsu model N6110 laptop to clean it from spilled wine. Which screws on back need to be unscrewed to allow this? And are there any catches on the front to remove?
    Sergeant:
  • 308 Answers
Need to remove a keyboard - remove-keyboard-fujitsu-laptop-800x800.jpg Remove the Keyboard on a Fujitsu Laptop
Fujitsu makes several series of laptops, with multiple models in each series. Some Fujitsu keyboards are attached with only a few tabs and can be removed with little hassle, but other laptops require more steps to remove the keyboards.
Difficulty:Moderate Instructions Things You'll Need
  • Flat, hard piece of plastic
  • 1Prepare a clean and organized workspace.
  • 2Turn the laptop off. Turn the laptop over and slide the battery switch to pop out the battery.
  • 3Turn the laptop back over and remove the keyboard bezel, the thin piece of plastic directly above the keyboard, by prying it up with a small flat object, such as a hard piece of thin plastic.
  • 4Lift up the keyboard and flip it over to rest on the mouse/palm rest.
  • 5Disconnect the motherboard connection by carefully pulling down on the two tabs on either side of the connector. After the connection is unlocked, gently pull the cable to disconnect it.
  • 6Remove the keyboard.
Tips & Warnings
  • Discharge any static electricity by touching a metallic surface before working with your computer, to avoid damaging sensitive circuits.
Posted on May 20, 2011
Keyboard has nonfunctioning keys
You will need to replace the keyboard. Usually they are attached with a coupe screws on the back of laptop with a keyboard symbol and/or latches screws on the front just above keyboard. They may be under the bezel. Keyboards usually run $100 from the manufacturer or parts outlet.
Dec 15, 2012 | Computers & Internet
Keybd keys are sticking
Be prepared to buy a new keyboard... Remove AC and DC power before working on laptop. Many laptop keyboards come off with the removal of 1 to 5 screws from the bottom. Some, however, require the palm rest to be removed, then a couple of screws that hold in the keyboard. Be careful when removing and replacing cables.After removing keyboard, rinse with water and let dry thoroughly before re-attaching and powering up. You cannot remove individual keys, so don't try.
Apr 12, 2010 | Fujitsu LifeBook S6510 Notebook
I forgot my bios password. My hash code is: 2703 7116 5722 4662 2670
If you don't know the system(BIOS) password for your System, forgotten it, or its not accepting it again, then you might have to reset your CMOS.
Which means you will have to unscrew your system, remove all cables supplying power to the board, locate the CMOS battery and remove it for a few seconds, then replace it and screw your system back.
This will reset your system's CMOS back to its Factory default settings.
(If you cant unscrew your PC yourself, you can just get a good technician to do it for you instead.)
Hope it helps.
Nov 24, 2009 | Fujitsu Siemens LifeBook N6110 Notebook
How to clean spill out of keyboard on hp pavilion dv7 1245dx
Best thing to do is to take the keyboard out of the laptop. There is usually a top cover above the keyboard that needs to come off. Then there is some screws holding in the keyboard, unscrew those and then unhook the ribbon part of the keyboard off of the motherboard.
Then at that point take a paper towel or washcloth with glass cleaner and clean all around where the spillage is.
Also clean off the keyboard is well and let it sit for a day so it can dry out.
Then put the keyboard back and see if the keyboard is working properly, if not then you'll need to replace it.
Oct 24, 2009 | HP Pavilion dv7-1245dx Notebook
Need to clean keyboard
hi yes you can clean the keyboard. i am placing three website links which clearly tells the steps to clean a keyboard
http://www.compukiss.com/care-maintenance/clean-the-keyboard.html
http://www.helpwithpcs.com/maintenance/cleaning-keyboard.htm
http://www.pcworld.com/article/112041/stepbystep_keep_a_clean_keyboard.html
here is another link which has a video about cleaning the keyboard.
http://www.ehow.com/video_2026_clean-computer-keyboard.html
Hope this website link be useful.
Apr 17, 2009 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
My dog peed on the screen/keyboard of my Toshiba Satellite laptop. Now we can't turn it on. Is there any hope of rescuing this machine?
There are a couple of things that probably got wet.
First of all, if it is still wet, you need to get it upside down, and get it open to dry it out, use alcohol to clean off the stained areas.
If you remove the screws on the back, and get the power strip with the lights on the top of the keyboard off. It pops off very carefully, but you need to unscrew the retainer screws poss in the battery compartment, or just on the bottom.
Also, once that strip is off, you should be able to unscrew a couple screws to get the keyboard off. There might be a screw or two on the bottom again, holding the keyboard down.
My guess is the keyboard is hosed, literally. I just had a customer who has a wine spill, and after clean up, everything but the keyboard worked.
Make sure you clean out the power area, up by the power switch, speakers, and whatever else is up there.
Worst case, you might need to take it to a repair shop to get the whole body cleaned out down into the motherboard.
Lastly, you can carefully remove the monitor faceplate with the screws hidden by rubber buttons, and then look at the electronics on the bottom and see if they are stained and wet. Your inverter could have gotten wet. That is the slim little metal/covered device at the bottom of the screen.
Get it dried out, and cleaned with alcohol. Many times the keyboard has to be replaced, but it still should start up if the rest of the computer is working ok. It depends, some models will not start up with a keyboard that is bad.
Apr 13, 2009 | Toshiba Satellite A85-S107 Notebook
I need to know what kind of drivers do i need for my fujitsu n6110...
It depends on what you want from your laptop, for example if you have a wireless card installed and you wanted to utilize it then you need to download the drivers for that wireless card.
You can find all the drivers for your lapop here http://driverscollection.com/?H=N6110&By=Fujitsu
Please Rate, Thanks
Jan 09, 2009 | Fujitsu LifeBook N6110 FPCM60505 Intel...
Keyboard
unscrew the screws at the back o f the laptop..Now you can remove the keyboard with the help of a FLAT screw driver..
Cheers...
Jan 08, 2008 | Averatec 5500 Notebook
HP DV 1000 Keyboard Replacement
to get old keyboard out you need to take battery out of back and there will be 2 screws with a keyboard symbol by them unscrew them and then just pop the keyboard out
Dec 03, 2007 | HP Pavilion dv1000 Notebook
Bios password
You have to locate the cmos battery on the motherboard and remove it for a few minutes, and possibly need to locate the clear cmos terminals and short the cmos terminal pins, but the name of the pins you need to locaye depends on the motherboard, normally JBAT1 terminal or CLRCMOS or CLRCLK or similair.
Sep 24, 2007 | Fujitsu Siemens LifeBook N6110 Notebook
Fujitsu Siemens LifeBook N6110 Notebook Logo
394 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
