Question about Whirlpool GEW9250 Electric Dryer
My panel reads, "Control Locked". How do I
  • Whirlpool Master
  • 8,220 Answers
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Press options and select for 10 secs till LOC is no longer displayed
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
Typical service manual for a front loader Duet
Your tech sheet info
Posted on May 20, 2011
How do you unlock a whirpool duet control panel?
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. This unlocks the control panel so that the washer is ready for use.
Read more : http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html How to Unlock the Control on Whirlpool Duet eHow
Sep 29, 2015 | Washing Machines
Tip
This code worked to hide the folder but it would not unhide it. I tweaked it and...
In an earlier post I had written about how to create an invisible folder. That’s a method to create a merely invisible folder with no real protection.
Now, here we will see how to create a folder that will not just be invisible, but also require a password to reveal it and open it. The best part is that you don’t need any special software to do this. Just plain old Notepad is all that you need.
Here is the code that you need:
cls
@ECHO OFF
title Folder Personal
if EXIST “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}” goto UNLOCK
if NOT EXIST Personal goto MDLOCKER
:CONFIRM
echo Are you sure u want to Lock the folder(Y/N)
set/p “cho=>”
if %cho%==Y goto LOCK
if %cho%==y goto LOCK
if %cho%==n goto END
if %cho%==N goto END
echo Invalid choice.
goto CONFIRM
:LOCK
ren Personal “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}”
attrib +h +s “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}”
echo Folder locked
goto End
:UNLOCK
echo Enter password to Unlock folder
set/p “pass=>”
if NOT %pass%==pwd123 HERE goto FAIL
attrib -h -s “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}”
ren “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}” Personal
echo Folder Unlocked successfully
goto End
:FAIL
echo Invalid password
goto end
:MDLOCKER
md Personal
echo Personal created successfully
goto End
:End
Now here is what you need to do:
Just copy the above code and paste it into Notepad. Save it by giving it any name you choose. Assuming, the file is called secret.txt, change the extension to ‘.bat‘ so that the new name becomes secret.bat. What you get is a batch file. You could actually save one step by saving the file in Notepad directly as secret.bat by enclosing the file name like this: “secret.bat” . This batch file is the one that you need. You can edit this batch file to change the folder name and the password. To change the name of the folder that is created, change the ‘Personal’ (in bold in the above code) to any another name you choose. Likewise change the ‘pwd123′ (in red in the code) to anything else.
Now let’s see how to use it. Place the file in the location where you would like to create your protected folder. Run the batch file by double clicking on it. This will create a folder named Personal in the same location as the batch file. You can now open this folder and place any files in it. Once you are finished, run the batch file again. You will be asked whether you want to lock the folder. Entry ‘Y’ (for Yes) and hit Enter. The folder becomes invisible. To retrieve the folder, run the batch file again. You will be prompted to enter the password. Enter the password, hit enter and voila! the folder appears.
Important: The batch file acts like a key to open the locked folder. So once you have created and locked a folder, do not keep the batch file in the same location since anybody can open the batch file and view your password. So I would suggest that you keep the batch file in a separate and safe place or better still keep it on your pen drive or flash drive. That way when you want to open the folder just copy the batch file to the location where you have your protected folder and run it.
Do remember that the above method is not intended to act as a substitute for the numerous free and commercial softwares that are specifically designed to provide security and encryption to your data.
Update: I got comments saying the code does not work. Of course I did check it before posting it here. But I have identified the problem. The problem is with the straight double quotes used in the code in this post. Once you copy the code you would also need to change each of the double quotes with your keyboard double quotes. That might seem a lot of work for some. So I thought it would be easier to give away the batch file itself. You can download the file here. (Use right-click and ‘Save Target as’ or ‘Save Link as’).
on May 07, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Locked out front control panel while in menu. Now I can't unlock front control panel and I don't have original remote control or owners Manual. Help me please. The front panel is all I use for DVD pla
Hi there, if you know what model it is you can do a google search for the owners manual. There should be a sequence of buttons you can push or hold to reset to factory/default settings.
Jan 25, 2013 | Televison & Video
Unwrite protect Micro SD card?
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your sd card drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your sd drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Jun 22, 2012 | SanDisk 4GB microSD High Capacity Memory...
THe main screen reads "card
try to look at the side of the card it might be locked then unlock it
Jun 28, 2011 | Samsung S860 Digital Camera
When the "bake" button is
hello,the control is locked. i belive if you hold the time button for 5 seconds it will unlock. hope this helps please rate me thank you...
Jun 07, 2011 | Ovens
How do I turn off the "control locked" indicator
If you are referring to the Control Lock on a Whirlpool Duet, Kenmore Elite, or Maytag Epic series front loader, this is built-in a safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
The following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more significant problem other than a simple operator control button issue (such as an operator console problem or main control board issue).
NOTE: Each one of these washers come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot if you cannot get the control panel to unlock.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
May 18, 2011 | Whirlpool GHW9100L Front Load Washer
Light reads "control locked" and washer won't work
Please Turn On your washer and hold the END OF CYCLE button for about 10 seconds and that would surely unlock your washer.
Dec 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control panel reads control locked
You problem have locked the control. There is a button on the front panel that says control lock. If you push adn hold this button for 3 secs the control locks or unlocks.
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
75 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
