Question about Frigidaire Dryers
My dryer reads loc model faqe7073kwo how do I fix please help.
2 Suggested Answers
Jahn27
  • 1554 Answers
SOURCE: Kenmore electric dryer--model 41784092500. When
It means the control is locked to avoid having someone accidentally start or stop the dryer. Press and hold the Options and Select buttons for 10 seconds or until the “LOC” on the display is cleared. Locking the control is done the same way it is unlocked.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 23, 2010
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Im having a problem with my washer it won't work and its flashing loc
Good Afternoon Jesslyn, I am happy to assist you!
I understand your washer is not working and flashing LOC; however, I see that your question is listed under Frigidaire FEX831CS (Top Load Stacked Washer/Dryer). This specific laundry center does not have a digital display. May I please have your model number? You can typically locate the serial tag, on the upper front as you open the door.
In the meantime, if you have a front load washer, I suggest pressing OPTIONS and SELECT at the same time and hold for approximately 15 seconds until "LOC" is no longer displayed. I hope this helps!
Thank you - Z.
Apr 05, 2014 | Frigidaire FEX831CS Top Load Stacked...
Dryer will not start. Has LOC error code.
Hello Luz - This is AP and I'm happy to assist you!
It appears your Frigidaire dryer console Control Lock has been activated. Without knowing your specific model number I can suggest to simply press and hold the Options and Select buttons at the same time until LOC is no longer displayed to deactivate the lock. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
Mar 03, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Error code loc
please read this over your error codes are invalid.
Jan 23, 2014 | Frigidaire Affinity FAQE7011KW Electric...
When I press start on dryer, the screen says LOC and it will not start. The lights are working but the cycle will not begin.
Which make and model of dryer do you have? The LOC code suggests that the child lock feature is enabled. (This keeps small children from starting the washer or changing the programming.)
Depending on the brand/model, you need to press and hold one key or a pair of keys for 3+ seconds to disable the feature. The key(s) should have a label on or below it/them in a very fine print telling you which key(s) to hold. The likely key is the Pause/Cancel button. On some LG dryers, it is the Wrinkle Care button. Some appliances will have an icon with a small face and a padlock indicating the appropriate key(s).
Please add a comment with your dryer model and I'll check which key(s) set the child lock for that appliance.
I hope this helps.
Jun 22, 2011 | Dryers
Loc on dryer
"LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. This will fix the issue.
Thank you !!
Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
The LOC flahes on my display, it allows me to pick a cycle but i can not start it. Please help, i tried to press options and select at the same time for the LOC to stop flashing...is there anything else...
Thank you !!
Jun 19, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please help
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Apr 15, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Kenmore electric dryer--model 41784092500. When I press the Pause or Start button, all the lights flash and then it reads ''err'' and ''loc''. What does ''loc'' mean. Sears will not tell me. They want to...
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 29, 2009 | Kenmore 84072 Electric Dryer
Dryers Logo
78 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
