Question about JVC HD-52Z585 52" Rear Projection HDTV-Ready Television
I have a jvc hd52z585. while watching tv it turned off and the lamp light and the power light are blinking at the same time. i have unplugged the tv for a couple of hours. when i plugged it back in it does the same thing. please help me figure out what is wrong with it
  • 373 Answers
Very easy.
there is 1 thumb screw behind left speaker grill.unscrew it to remove the grill.the lamp is behind that.after changing the lamp,go in to CUST.MENU,scroll down to reset lamp timer. Best price for lamp is pureglare.com. Inspect the lamp for internal glass particles for 100% verification of being bad. Also at the root of the glass stem in the middle look for bubbling of the glass. This is another sign of a bad lamp.
Posted on May 20, 2011
My jvc projection screen tv AV-48WP74 power light blinking, no picture, but wont turn off
u have to unplug it for the light to stop blinking than put new lamp and housing in and it should work just fine after that
Aug 20, 2013 | JVC Televison & Video
My jvc projection tv power light blinking, no picture and wont turn off
u have to unplug it for the light to stop blinking than change the lamp for the picture and it should work just fine
TV won't turn on - the front blue power light and red lamp light blink. Does this mean the lamp needs to be replaced?
Yes.The tv projection lamp inside the tv right now it is been inside the tv like a 1 1/2 or 2 years already.The tv been on daily and in used like 4 or 5 hrs tv watching daily?Yes,than the tv projection lamp life are ending and the causes.
May 08, 2011 | JVC HD-52G886 52" Rear Projection HDTV
My power light and lamp/standby light blinks.... no picture or sound... Grrrrr help pls
The projection lamp on this tv like 1 1/2 or 2 years has not been replaced in this tv and it turn on and watches tv 4 or 5 hours every day?Yes,than the projection lamp life is over.Require replacing a projection lamp.
Oct 18, 2010 | JVC HD-52G786 52" Rear Projection HDTV
When i turn power on the power light comes on but no picture the lamp light comes on then starts blinking?
The tv projection lamp has not been replaced in this tv like 1 1/2 or 2 years?The tv been on an watches tv like 4 or 5 hours a day?Yes,than the projection lamp life is over.The tv require a new projection lamp.
Oct 12, 2010 | JVC HD-52G886 52" Rear Projection HDTV
Power will not come on. when tv is turned on light comes on then begins to blink, no picture and have to unplug to stop light from blinking.
Depending on how old it is it may be a lamp issue. Check your manual to see what the blinking light means. if it's a lamp issue you may need a new lamp and have to reset the lamp timer.
Jan 16, 2010 | JVC LT47X579 47 in. LCD TV
Please help!!! Problem with JVC DLP TV
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Feb 03, 2009 | JVC HD-52G786 52" Rear Projection HDTV
JVC TV WENT OFF. TURNED IT ON AND THE LAMP LIGHT STARTED BLINKING
If the Fan is clogged up with dirt set will not run fan must be working.
Dec 01, 2008 | JVC AV-30W776 30" TV
Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Apr 21, 2008 | JVC HD-52Z575 52" Rear Projection...
JVC HD-52Z585 52" Rear Projection HDTV-Ready Television Logo
123 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
