Question about Akai PT4298HD Rear Projection Television
Picture has lost color.......everything is basically red.
  • Akai Master
  • 3,459 Answers
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
e87380cPicture has lost color.......everything is - 69189a5.png=
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Please do us a favor and rate this solution after reading
Posted on May 20, 2011
My 52 inch akai i bought used at a lawn sale now when i turned it on and went to menu to adjust the color i seen that it is eather red or green you cant adjust it to make people and things look normal now i expected when i got it that there was going to be something wrong with it but i thought it might not take to much money to fix it as i had no other tv low income here can you tell me what might be wrong thank you
Posted on Aug 17, 2011
Shadow effect on picture. Picture is fine but there is a red shadow tint to everything (basically everything is written twice, but not in the same spot)
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
Jan 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Loss of red color and dual images
Ur convergence is dead,U know how to solders?Buy a convergence kit,use what in that kit.ur tv should be back to normal.This website have the convergence kit
Tv repair World.com.
Oct 21, 2009 | Hitachi 57F500 57" Rear Projection...
After tv warms up, red colors/tones disappear
i have the same set. try bringing down the color temp, for that matter maybe even lower the rest of the settings too. sounds like a lamp replacement?
Apr 22, 2009 | Televison & Video
Picture is very green & blue very little red
caroldickers,
if the picture have lost red, possibly there's a loose contact somewhere in C-board area of your screen. The only way to revive the red color is to check and resolder the c-board are.C-board is located at the back of the CRT unit.
Jan 14, 2009 | Televison & Video
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Too much red color in the picture
SOUNDS LIKE U HAVE LOST THE GREEN OR BLUE COLOR GUN
Aug 27, 2008 | Hitachi 51G500 51" Rear Projection...
2001 sony wega 36" tv tube
If you turn the color all the way off the picture should have good black and white if not the crt is at fault. If it is good it could be the jungle ic or the possibly the red color driver in the crt board
Apr 06, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Everything in picture on television are green
The basic colors in the TV is RGB & each color has a diff amplitude & frequenc. It seems that the IC controlling the RED & BLUE has lost some of it's capabilities due to lower voltage supplied/regulated by the chip, which generally happens after quite long period of usage. However this seems an inherent fault with visio & most of the early sets do not have this problem sorted out at the manufacturing level & is a problem for most of TV's which are unpredictable & could occur in a month or year. If still under warranty, pressurize your dealer/distributor/service center to sort it pronto or ........... face the consequence..........sodeep
Sep 23, 2007 | Televison & Video
Akai PT4298HD Rear Projection Television Logo
254 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
