I have an Electrolux EWF1495 front load washing machine. The front seal has gone all mouldy. Is there any special cleaning agent for that. I have tried cleaning it before but it comes back. Or should i get the seal replaced.
ngfam1
  • 639 Answers
SOURCE: just gota new ewf1495 front
Peace Friend,
ngfam1 At your service!
With an error code Flashes the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
YOU HAVE A ONE YEAR WARRANTY LET SERVICE RAN THEIR KEEP AT NO COST TO YOU!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
  • 1462 Answers
SOURCE: Door Seal
not too bad a job
turn off mains. undo clamp that holds door boot to cabinet and peel off the boot.
the seal is then held onto the tub either by a large circular spring or maybe a clamp with a screw.
if it is a spring, then just force the boot downwards and pull outwards and the boot will come off.
if it is a clamp, undo the clamp and pull the boot off.
look at the new boot and you will see a groove that slips onto the lip of the tub. lubricate this groove liberally with washing up fluid or similiar.
start at the top and push the groove onto the lip. work in both directions round the boot forcing the groove onto the lip until entirely in position.
if a clamp was fitted, just put the clamp in the outer groove and tighten
if it is a spring, this is more difficult and you will find an extra pair of hands helpfull. stretch the spring and push into position in the outer groove.
fit the boot to the cabinet and replace the clamp
test for leaks on rinse cycle as water level is higher. there will be some foam from the washing up fluid.
remember to make a note of which way up the door boot was fitted as there is a top and bottom
Posted on Sep 05, 2008
  • 135 Answers
SOURCE: how to change a door seal on a hotpoint wma58
Firstly remove band holding front of seal then remove the screws from the door lock and push lock through.
Remove kick plate from bottom of machine &take out 2 screws holding front of machine.
Remove soap drawer &take out screws behind it then bring facia forward & slide to right to remove. Take care at this stage not to disturb wiring on cicuit board. An extra pair of hands would be helpfull to hold it.
Remove screws holding front as you did at bottom then lift and remove front panel.
Seal is now easily accessed.
Post back if any further assistance needed.
Thankyou for using Fixya.
Posted on Jan 26, 2009
  • 10865 Answers
SOURCE: Mouldy Door Seal
Use tilex to remove the mold. Then see what happens. If the mold comes back right away it may be a problem with the rubber gasket not seating as it should. Let me know. And please rate my solution. thanks.
Posted on Feb 02, 2009
  • 44 Answers
SOURCE: How do you clean the mould build up off the
Bleach:Water solution 1:2 should kill the mould effectively.
What they should have told you when you bought this machine and what it almost certainly says in the owners manual is that front-loading washing machines, all brands, are prone to this problem. You must wipe the rubber gasket/door seal off when done using. Every time.
Dumb, I know, but necessary.
Posted on Sep 08, 2009
How to do a electrolux washing machine ewf1495 reset
If you mean "reset program" than turn program selector to "OFF" position and than choose new one, otherwise unplug from wall socket.
Dado
Jul 26, 2015 | Electrolux Washing Machines
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
I have a front loader washing machine. The rubber inside is going mouldy. I have tried to clean same without success - any suggestions!
Unfortunately, once the door seal goes mouldy it is impossible to get clean. Only option is to replace seal. Once seal is replaced, you need to wipe it dry after each wash and leave door ajar to prevent reoccurence of mould.
Mar 09, 2010 | Maytag Washing Machines
The rubber section of my Hotpoint WF640P has gone mouldy
The problem is basically caused by doing too many low temp washes.
The scum you refer to is actually bacteria that is bulding up on the door seal.
To avoid this problem reoccuring, the best thing to do is to have the door seal replaced, and periodically do a high temp wash with powder in, but without clothes..
This is called a maintenance wash, and is recommended by most manufactures
Also, after each wash, clean and dry the door seal, this will help prolong it's life.
Hope this helps answer your question.
Please rate my solution.
thanks.
Dec 23, 2009 | Washing Machines
How to clean the rubber seals of a front loading washing machine
You can use wire scouring pad with a cleaning agent, but it probably will not remove all stains, you will not harm the seal doing this.
The prob is originally caused by doing too many low temp washes, you should do a 95 degree wash without clothes in, but with the powder in at least once a month, it is called a maintenance wash, and all manufactures recommend you do this on a regular basis.
If it is really bad then the only satisfactory solution is to replace the seal, and keep doing a hot wash periodically.
Thanks.
Oct 19, 2009 | Electrolux Washing Machines
Rim around machine is mouldy. How do I clean or replace it?
run your washer thru a wash cycle with a cup of vinegar instead of soap. Do not put clothes in with it.
May 20, 2009 | LG WM2688H Front Load Washer
How to change a door seal on a hotpoint wma58
Jan 26, 2009 | Hotpoint WMA58 Front Load Washer
Replacing door seal
Try washing the seal with jiff and a scouring pad in warm water.Depends on how well it is ground in.
You may have to replace with new seal.
slimjim1
Nov 25, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Mildew smelling towels and no separate rinse cycle
the problem is your door seal if you close the door after a wash then what happens is the water goes mouldy on the inside of the door seal what you need to do is replace the door seal you will never get rid of the smell without replacing it never close the door after a wash always leave it open to make sure its your seal the easy way is to look at the inner part of the seal and it will be mouldy only thing you can do
Oct 30, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
