Question about Ruud Central System Air Conditioner
Ruud furnance/ac central air
My ac is blowing air but it is not cold the ac is only 7years old the local service tech comes out removes the bottom panel and blowes throught the tubes to the condensation pump i believe and then he leave and it seems to work for a period of time, the real problem is he charges 70-100 dollars each time, what can i do to eliminate the need to call him
  • 1,800 Answers
I can help u but mikep858 i need u to give me the model of this ac okay the correct one
best regards
Posted on Aug 14, 2008
Why does my AC keep running
needs recharged probably by a certified repairman
Jul 13, 2016 | Ruud Central System Air Conditioner
Furnance comes on but the air stop getting cold just blows air ....what could be the problem
It sounds like it could either be low on refrigerant or the compressor has stopped working. Start by verifying that all the breakers and controls are in the on position. If the outdoor unit is running but you have no cold air, you may need a HVAC company at this point.
Sep 08, 2013 | Ruud UBHC Air Conditioner
Air Handler--Noisy Harmonic Sound
DO NOT buy a RUUD system. I purchased a complete system in 2010 & have had multiple issues since - - new coil, high humidity levels, condensation on my walls when the furnance is on, and now when the outside temp is 90+ degrees the AC unit shut off and only blows hot air. THey've replaced the "board" and I was told that RUUD is aware of multiple problems with the 2010 units but will NOT recall them.
Nov 01, 2012 | Ruud UAMB Air Conditioner
RUUD AC cycles warm & cold 24/7
Hello Anna Sounds like the compressor is overheating and stoping on overload internally.Then it cools down restarts and runs into overload again.I would like to see the freon pressures when running.Could have a clog/restriction in piping.I dont like that you went thru a compressor already, the original installition is suspect.The original (1st) failure cause must be corrected.Check the TXV valve replace, filter/dryer look for a kinked pipe are ideas for overheating.Make sure condenser coil is free (ari flow)& clean also.
Jul 30, 2010 | Ruud UBHC Air Conditioner
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
My heat unit will not blow hot air unless we go outside and hit a button on the back bottom of the unit. Once we do that it will blow hot air for that cycle. when it is time for it to come on it is cold...
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Nov 07, 2009 | Ruud Central System Air Conditioner
Where is the capacitor located in a trane central air unit?
the cap and all other electrical components are safely placed inside the unit's box. You have to take the side off of the unit and the metal box is on top please throw the disconnect of and remember there is still 24 volt live inside. The 24 volts is coming from the furnance.
Aug 13, 2009 | Ruud Central System Air Conditioner
Ruud heating/ac unit blowing only cold air in heating mode
Do you have gas or electric heat. If you have gas then you do not have a heat pump. You should in most cases have a red,yellow, white, and green wires coming to the thermostat. R should go to rc/rh G should go to green Y should go to Y and w should go to W. Also the switches on back should be switched to non heat pump and gas rather than electric. Hope this helps.
Feb 15, 2009 | Ruud UBHC Air Conditioner
Central air conditioner
check the filter also sounds like a low freon charge.
Jul 29, 2008 | Ruud UBHC Air Conditioner
Ruud Central System Air Conditioner Logo
149 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
