Question about Lorex Sg5550cl Home Video Observation System
I have a lorex sg5550cl that does not want to work. When i turn it on it gives me upwards scrolling bars and no audio, as well as it interferes with my wi-fi. it actually shuts down my wi-fi. and jams my computer. when the wi-fi is turned off it still does not work, just giving me the messed up lines, but if it messes up with my wi-fi, im sure it messes with my neighbors. any one have any suggestions?
Lorex eco 130 can not get to menu, screen shows Lorex page
There should be a paper clip size hole somewhere on the back of the unit. If you depress the button in there it should be the reset. The problems sounds to me more of a hard drive issue though.
Jan 17, 2015 | Lorex ECO 16Channel Security DVR with 16...
Scroll bar does not work
Hi candace ann buchholz,
If the Mouse USB receiver is connected to the computer via a USB Hub, disconnect the receiver and plug it in the computer directly. Hubs interfere with mouse wheel signals.
Feb 22, 2014 | Computers & Internet
Too much power and now lorex camera wont turn on
You destroyed the camera. Lorex won't cover that under warranty either. Since you didn't use the power adapter that came with the camera you'll have to get another camera and connect it correctly
Jan 16, 2014 | Lorex Home Security
Does the lorex dvr support my MAC os on my pc
Hi Kavya,
Which model of Lorex DVR are you using? Currently, only some of our security DVRs are compatible with Mac OS X (via Safari). Our line of Edge and EDGE+ DVRs (LH300 Series) are Mac compatible and offer full remote viewing, playback, backup, and setup using Safari.
Please give us a call at 1-888-42-LOREX(56739) or visit us online at
Cheers, Lorex Support Team
Nov 11, 2010 | Lorex (L3501090)
Need wiring diagram for Lorex SG6184S. Cut off connectors and hardwired camera, not it does not work.
Lorex Corp SG6184S Weatherproof Mini Color Security Camera with Night Vision,where can i download manual,wanting to set it up to my vcr and clueless how this is done,i have camera's yellow white cables in tv[video/audio but unsure how to connect or what to do so i can record from vcr,please specifies
Sep 03, 2010 | Lorex Corp SG6184S Weatherproof Mini Color...
My Lorex SV-01-RCV Wireless A/V instructions were lost in our move and I need help with the set up. Could you please help? I can not remember the correct connection.
You should have a 2-wire cable with Yellow, White and Red RCA plugs on each end.
The Yellow line is video out.
The White line is Left channel audio out.
The Red line is Right channel audio out.
Since your RCV only has two RCA jacks use the Yellow line for video and the White line for audio.
You should also have an "F-connector for co-axial cable.
If your TV set does NOT have audio and video jacks hook that to the co-ax antenna connector on the back of your TV set.
Set the RCV for either channel 3 or channel 4 and do the same with your TV set.
The RCV unit has four receive channels which must match up with the channel selected on the CAM or TX unit.
You can scan all four channels either by auto or manual.
If you only have one CAM or TX unit it probably doesn't matter which of the four you use unless you have a computer ROUTER which interferes with one of the four channels.
If so, select the 1, 2, 3, or 4 channel which has the least or no interference manually.
Bil Munsil
Mesa AZ
Hams should be seen as well as heard.
Dec 30, 2009 | Home Security
Scrolling text interfering with audio when docked
Thats a new one. I wonder if there is some sort of RF interferance going on. Are there any other attachments plugged into your nano or the gear4? how about wireless?
May 19, 2008 | Apple iPod nano 3rd Generation
Interference audio and on-screen
Try an HDTV. If you only have a standard TV, try a different one. I had the same problem and then bought a 1080p 16:9 aspect ratio HDTV and everything cleared up completely (sound and video). Update the ps3 to version 2.2 as well (just came out last night). Good luck!!
Mar 25, 2008 | Sony Playstation 3 (PS3) Console
Lorex Sg5550cl Home Video Observation System Logo
46 people viewed this question
Top Lorex Home Security Experts
Lawrence Oravetz
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
