Question about Brother Sewing Machines
Where do you add oil to the Brother XL-2021 - Brother Sewing Machines
Where do i oil my brother xl 3022 please. Just stopped mid sew
Follow the instructions in the owner manual. Improper oiling could damage the machine.
Aug 22, 2017 | Brother Sewing Machines
I have a Brother XL-3750. I can find nothing in the manual concerning the oiling of the machine. Does it never need oiling?
Use light machine oil for the cams and gears underneath but keep away from all areas that may have contact with your material.
Feb 23, 2017 | Brother Sewing Machines
How do I replace the bobbin hook after cleaning my Brother XL-3030?
you may be able to enlarge the manual page:
Brother XL 3030 User Manual Page 60
The hook (half-moon piece) needs to go in first, but you may need to wiggle it to seat it and then hold it while you fasten the outer retaining ring (hook race). Flip the levers up to hold the ring in place. Then install the bobbin case.
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
FWIW, my machine oiling instructions say to apply a drop of good quality oil on the outer edge of the hook race lip where the hook rubs as it turns. But, your manual should explain where to oil.
Dec 22, 2016 | Brother XL-3030 Electronic Sewing Machine
How to oil my brother xl-3100
Consult your owner's manual for maintenance instructions. Use only good quality sewing machine oil--not old brown, foul-smelling oil, 3-in-2, WD-40, or cooking oil. Apply only 1-2 drops of oil as instructed.
Oct 09, 2015 | Brother Sewing Machines
Why wont my machine move?
If it's been sitting unused for a long time, the lubricating oil will have evaporated and turned to varnish. Use only sewing machine oil to lubricate it after carefully cleaning and loosening all the moving parts. Forcing it will break something expensive.
May 07, 2012 | Brother XL-2600
Brother XL-6562 sewing machine is not feeding fabric through properly
Oil might help but it sounds like you don't have enough pressure on the foot. You can take the casing off where the light is and there is a screw back there that controls the tension on the pressure foot. It is not meant to be changed by anyone but a professional. I've changed the tension but it wasn't easy. If you are still interested let me know and I will try to explain.
Oct 07, 2008 | Brother XL-6562 Mechanical Sewing Machine
Oiling XL-5700
You oil this machine anyplace that it moves and rubs. Needle bar, joints that drive the needle bar,end of each shaft, presser foot bar,hook race etc. Do not use 3 in 1 oil. Use a good quality sewing machine oil.
sewman7
Sep 01, 2008 | Brother XL-5700 Mechanical Sewing Machine
Sewing Machines Logo
87 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
