Question about Toro Lawn Mower With Toro Power Tools
My mower is four or five years old and has done well, but now when it is used it runs great for about fifteen minutes and then sputters and dies. When it does this it will not restart until it cools
  • 707 Answers
The oil level is low. when the oil drains from the engine it fills the base to the level of the sensor. When it runs it takes a little time for the oil level to drop below the sensor..........Hope this helps.
Posted on May 20, 2011
There is a flashing symbol- black rectangle with two white triangles one on top of the other mower stops but will restart after a few minutes. Cub Cadet LTX-1050, v twin1 Hydrostatic
Make sure air filter is clean or replaced. Check oil level. Change oil if not done this year. Remove plug, clean and gap. Ensure gasoline isn't over 30 days old and use a gas stabilizer if gas cap isn't marked E85.
Jun 18, 2016 | Cub Cadet Garden
LTX 1000 craftmans rider 18 hp ohv kohler rpm fluctuates, then dies. I let it sit for ten minutes and then start it and mow for a few minutes and then it does the same thing. is there a safety cut out
There could be some type of contaminate in your fuel/lines. Check for that!
Then check your fuel filter. and hoses.
Your carb needs to be rebuilt!
May 26, 2012 | Craftsman Garden
2 year old craftsman 42" deck tractor runs fine for 15 minutes then sputters and dies. Will start, run 2-3 minutes, die again. Leave sit will run for 20 minutes.
if it restarts immediately, check the vent in the gas cap for restriction. also, the solenoid on the bottom of the carburetor may be sticking or getting weak. if you have to let it sit for awhile before it retarts, the ignition module may be breaking down when it heats up. i'd bet on the gas cap or solenoid though
Sep 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower runs good for fifteen minutes then the
Mine did this too. THe semi-transparent fuel filter will look like no gas is in it if you have the problem I had. The gas cap on the tank has a tiny breather hole to keep it from coming under a vacuum as gas runs out. Push thru it with a toothpick to clear the hole. That's all it was. But I did have some black debris clogging the filter and had same symptom.
Aug 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
MTD 12.5 HP Ride On Mower won't stay running
It could be a needle valve sticking or a mal-adjusted float but more common is a fuel filter that is restricted, once you use up the fuel in the line and float bowl it runs out and dies. A less common but easily tested issue is when the mower has run for the amount of time it begins to sputter and die, loosen the cap on the fuel tank just a bit, if it helps or resolves the issue the vent in the cap may be clogged.
May 26, 2009 | Mtd Garden
MTD Yardman push mower runs fine for awhile then cuts off.
Try buying a new plug first but if it continues then I would say that there is debris in the carb.
Apr 04, 2009 | Mtd 22" Yard Machine Push Mower
Toro Lawn Mower With Toro Power Tools Logo
144 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
