Rca r52wh77 colors are off and the picture seems to bow in from the top of the tv. what is the problem?
  • Vernon Johnson
    Vernon Johnson May 20, 2011
    good job man! that was very professional and that link put me right to where i needed it to be.
  • 10,515 Answers
This is a common problem on these sets. This is a convergence problem and you need to replace convergence IC's to fix the problem.
i`m going to give you two addresses where you will find the parts and instructions on how to do it and also some tools that you may need.There is also a free help line for the parts in case you have any problems with them.
This one is for the parts;
http://www.tvrepairkits.com/xcart/home.php?cat=3980
That is for your chassis ITC222A
This one is for the tools(recommended) if you don`t have them already :-
http://www.electronix.com/advanced_search_result.php?keywords=sd1284&x=8&y=5
That kit contains a desolder pump and some solder wick that will come in handy to remove the old parts.
This is all well documented and can be done in one afternoon/evening, just take your time (easy does it) and you`ll see that it will all come together and repair your set.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 20, 2011
On our rca hdtv model # R52WH77.. the tv is having like a 3d look on it and has a bow in the picture.. we bought the convergance repair kit from tvrepairworld.com and replaced the 2 parts it gives us.. ...
have you reset the convergence parameters after installing the kit to fix the option? Usually you will need to reset the defaults to get the outer edges back in alignment.
Aug 11, 2011 | RCA R52WM24 52" HDTV Projection Television
Rca 52inch hdtv
Please replace STK392-110 quantity 02 in your tv to fix convergence problem.
Above said part is available here.
Regards,
Sep 27, 2008 | RCA HD52W59 HDTV Projection Television
this is the conversion IC chip that controls the centering of the colors , vertical and horizontal
it needs to be replaced , $300 to have a tech come out , $30 for the part
Sep 04, 2008 | RCA P52937 52" Rear Projection Television
Tv help!!
ALright. you might have a simple inexpesive problem...MIght... first question If you go into setup menu do you have convergence option.. if you dont this it is a small special fuse that blows because of bad connections... can you solder electronic components. the parts about 5 bucks and takes less than 30 min to replace. Let me know if this is the case.
May 15, 2008 | RCA P52937 52" Rear Projection Television
RCA R52WH77 convergence missing from menu
THis is very common on these sets. there is a special fuse thats cause this.. kinda hard to get rca part number 259213.. .4 amp. the reason this blows is there is bad solder connections on the flyback. so when you replace this fuse you have to resolder these connections. so if you know how to solder and can find this special fuse. it is a fast and easy repair
Apr 08, 2008 | RCA P52937 52" Rear Projection Television
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Rca projection
Conversion problem most likely. Do your conversion controls work both colors in all 4 directions.
Jan 04, 2008 | RCA P52926 52" Rear Projection Television
HD52W59 bowed picture
Check your screen. I have the same problem with mine. If the screen has a ripple in it, it could give the same effect.
Dec 15, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Electro Med Services...
