Question about Watches
Battery for 20/1441 T205 - Watches
How do u change the battery in a gossip small ladies watch
  • Remove back
  • Locate battery and note how it is installed
  • Identify battery
  • Obtain replacement battery
  • Remove old battery
  • Install new battery
  • Check operation
  • Reinstall back
  • Set functions
  • Return to small lady
Oct 14, 2016 | The Watches
Need watch battery size for a fossil blue watch model number Tl-5073
  • Remove back
  • Find battery mounting. Note for later battery installation
  • Read battery type (not size)
  • Obtain exact battery replacement
  • Remove old battery; install new
  • Check operation
  • install back
  • Set watch
Sep 09, 2016 | Fossil Watches
Armitron watches need to know how to change battery
  • Remove back
  • Find battery location. Note mounting and polarity for later reference
  • Identify battery type
  • Install new battery exactly as noted in second step
  • Check operation
  • Install back
  • Set various functions
Aug 30, 2016 | Armitron Watches
Lost battery
RENETA Battery # 321
or
maxewell battery # SR616SW
Apr 07, 2014 | Kenneth Cole Kc9109 New York MenS Kc9109...
Have fitted a new battery but no joy, any tips I can try?
mcdevito75 here, Some quartz watches and I believe Citizen is on of which need the exact factory number battery installed / replaced. if you did use the exact battery number and the new battery is not working, remove the battery and carefully clean the battery contacts with a Q-tip and rubbibg alchohol do not soak the battery contacts just clean them. Also your new battery could be dead, who knows how long it was on the store shelf. Alaso wipe off any oil from your fingers on the new battery before you install it in the watch, make sure the battery is seated correctly in the watch, the back cover may also have to be installed back onto the watch to complete the battery circut for the watch to work. If all this fails you can try to contact Citizen online, Contact CitizenWatch.com and get their recommended battery size for your watch, OR, look for a small watch repair shop in your area. One Last thing, Your Citizen watches Quartz mechanism could also have gone bad, in this case you"ll need a new watch.
Feb 11, 2011 | Citizen Watches
My husbands new watch Armitron water resistant Quartz alarm chronograph, two tone blue face 20/1441 T205 ( water resistant 165 ft ) it came with no instruction manual,the alarm beeps every hour , anyway...
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
Feb 23, 2010 | Watches
Dead battery, how do I open?
I believe a local watch repairer will replace the battery for around 5$ that should include the battery, depends on the person.
Generally the battery is replaced by opening the back cover of the watch, in some cases special tools might be required.
the details of the battery read on top the one currently inside it.
Jan 30, 2010 | Watches
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Watches Logo
70 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
