Question about Photography
How to set a TSA007 lock attached to Samsonite luggage
5 Suggested Answers
SOURCE: samsonite attache case lock
I just used the following solution successfully...
thanx to whomever posted it.
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
If you still have a problem with the combination lock, contact the nearest authorized repair center to your zip code for repair assistance. Our warranty and repair information can be viewed at http://www.samsonite.com under the heading “Customer Service Repair Centers” for your reference.
We appreciate your loyalty and will continue to design products that are reliable business or travel companions.
Posted on Apr 10, 2009
  • 4 Answers
SOURCE: I lost my keys to
file an old key with a small 'L' tip or do the same with a hacksaw blade. The tip should be appx 1/2" x 1/8" with the 'L' on the tip. Try several tip sizes. Spray some oil inside first.
Posted on Jan 21, 2009
SOURCE: my samsonite hardcase luggage's centre no.lock not able to close
problem sloved
Posted on Oct 21, 2009
ChristenFihl
  • 5 Answers
SOURCE: how do I set the lock on my Samsonite tsa007
Locate a very small hidden button. Press it with a small stick. Turn digits to new code, and open again.
Just locate that button first, close to the zipper.
Posted on Sep 09, 2010
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
Open samsonite tsa007 lock
That number is the key number that TSA uses to open that lock. There is nothing available except to contact the maker. If you would rather replace it, they are not expensive.
Jan 14, 2014 | Samsonite Photography
Cannot lock
Pick your number. Look at the inside of the lock. There should be a little "slider". Slide that - it sets your number and then your lock should function normally.
Nov 12, 2013 | Samsonite Silhouette 12 Travel/luggage...
How to change lock code in TSA007 lock?
Nov 30, 2012 | Samsonite Tripod
How do I reset a 4 dial Samsonite combination lock
Hello sstacy1,
You can follow the steps below to fix your problem on how to reset your 4 dial Samsonite combination lock:
  1. Set the dials to 0-0-0. Find the lever or button next to the dials.
  2. 2If your lock has a lever, lower it and turn the dials to the desired numbers. Return the lever to its starting position.
  3. 3For locks with a button, push the button towards the dials and turn them to the desired numbers. Release the button.
  4. 4The lock is now set to the new combination.
Read more: How to Reset Samsonite Luggage Combination Locks ' eHow.comhttp://www.ehow.com/how_4761466_reset-samsonite-luggage-combination-locks.html#ixzz157Q4Ap
Hopefully it helps.
Thank you for using fixya
Sep 08, 2011 | Health & Beauty
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
How do I set the lock on my Samsonite tsa007
Mar 09, 2010 | Samsonite Tripod
Samsonite attache case lock
Dear Sir/Madam:
narrow space.)
your combination.
Apr 08, 2009 | Samsonite Tripod
Photography Logo
499 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
