Question about ASUS LCD Monitor
There is an icon at the top pf my monitor that I cannot get to go away. It says Splendid Deco with small icons underneath that say Splemdid off and Splendid on. It sort of bounces from one position to another. It is a real distraction. Please help, My email is cbalb56@gmail.com
  • 11,361 Answers
You can turn off ASUS Splendid software:
1) Right click on your desktop and select "Properties" to bring up your display properties;
2) Select the "Settings" tab and click on "Advanced" on the bottom right;
3) Select the "ASUS" tab on the top right and then the "ASUS Splendid" tab;
4) Unselect the check box next to "Enable ASUS Splendid"
Learn more from ASUS:
http://www.asus.com/999/html/share/2/icon/137/index.htm
You disable it or unstall the software.
Posted on May 20, 2011
Can anyone tell me how to remove the source and picture icon in the top left corner of my monitor? I won't go away no matter what the source is.
Sometimes the Icons are locked in the programs and you have to go into where it says uninstall or change programs. Look over the list that comes up and if that one is in there hit THAT ONE ONLY AND HIT UNINSTALL. Do NOT hit any others as it will take out the good ones too.
Sep 03, 2016 | Computers & Internet
Remove 'spledid demo'
Down load a program called "perfect uninstaller" Also "spyhunter 4" run one after the other removing all reference to Splendid.
Jan 01, 2014 | Computers & Internet
Screen turned side ways
Hold the CTRL key, ALT key, and press the up arrow key on your keyboard simultaneously. This might resolve the problem right away. If it doesn't, continue to the next steps. Try to navigate to the side of your taskbar opposite from your Start menu. Click the small arrow leading away from the small panel with the clock. Look for an ATI, nVidia or other icon related to your graphics card. Look at the box your graphics card came in if you cannot identify the icon. The box usually has the image somewhere in the design. If you do not identify the icon at all, look through your operator's manual for your graphics card to see what the tray icon looks like. Right-click the graphics tray icon and click "Rotation Settings." Turn the monitor's display around as you wish. Choose zero degrees as your angle if your monitor is upright.
or
Try pressing Ctrl + Alt + UP Arrow Key, or try Ctrl + Alt + and a different Arrow Key.
If that does not work: Right-click on empty Desktop > Graphics Options > Rotation. or Press "Ctrl-Alt" and an arrow key (left, right, up or down) to rotate the screen. Continue pressing the hotkeys and arrow keys until you reach the desired rotation. This works with most video drivers on Windows XP. If it doesn't, Click "Start," then "Control Panel," then "Display," then the "Settings" tab. Click the "Advanced" button. Check for an "Orientation" option. Select your desired orientation. Hope this helps.
Dec 27, 2012 | Toshiba Computers & Internet
HOW DO I TURN OFF THE SPLENDID DEMO ICON ON THE TOP OF THE SCREEN?
click on menu click on the down arrow button,so that you can see the system setup click menu to highlight the "splendid demo mode" click menu again ,and move the arrow button,so that the OFF is selected and finally exit out for menu
Apr 20, 2011 | Computers & Internet
ASUSVH236 HOW DO I TURN OFF THE SPLENDID DEMO ICON ON THE TOP OF THE SCREEN?
Sep 04, 2010 | ASUS Computers & Internet
Icons on top of each other. start button in wrongplace
lcd monitors have a auto resize button...
but for your icons... you can do this...
right click in any part of the window then arrange icon then choose if you want for name or etc.
Feb 11, 2010 | Acer AL2216WBD LCD Monitor
The problem is the monitor
if it is not that long since you bought it, i suggest you take it back where you bought it from for a full warantee.
or you could it is has been long since you had it take it to a nearest pc worker for new programming.
thank you
wonder
Sep 17, 2009 | LG W2753V PF Flat Panel 27" LCD monitor
Just set up monitor after we moved. The fonts on microsoft features are now small. Attempt to change font size (on control panel) are not successful. example of "features" = task bar words very small,...
anywhere on the desktop(not over an icon or folder) right click on the mouse and go to properties. A window called display properties will come up. On th tabs at the top click on settings.
There will be a slider bar called screen resolution, move the slider down and the windows icons and folders and fonts will get larger adjust this and keep clicking apply until it was the same size previously
Aug 22, 2009 | Acer Computers & Internet
My computer's display has moved!
I have seen apparently random movement on crt monitors..
Usually it needs nothin more than a small adjustment from the OSD (on screen display) if you have buttons on the front of your monitor they are for the OSD your manual will give you more detail about it. Or if you dont have a manual then having a little "play" will not do any harm if you dont adjust any settings.. You will normally see some icons in a box on the screen when you press the correct button on the monitor.
the icon you are interested in may look like two screens on top of each other
Aug 19, 2009 | Computers & Internet
Hpvs15 monitor problem
1. dry points in neck board.
2. R G B capacitors & pf
3. adjust the yoke presets
Oct 17, 2007 | HP vs15 15"LCD Flat Panel Monitor
ASUS LCD Monitor Logo
467 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
