Question about Century Body Opponent Bag
Flex 48 pool jetted tub motor doesn't start, hums and throws breaker
Hot tub comes on jets want start
most hot tubs have two motors. one is a circulation pump to move water when the heater starts and the other comes on when the jets are being used. from the sounds of it, the one pump isnt running properly
Oct 20, 2015 | Pool & Spa
Why wont hot tub heat with jets on losing temperature on 110 volt
My first question would be about the outside temperature. What is the outside temperature?
Hot tubs that are designed to operate on 115v only have 1.5kw heaters and if the outside temperature is below 50 deg F they tend to not keep up to 103 deg water while being used. They are also designed to not heat while the high speed pump is operating.
Does it stay up to temperature on a normal basis?
ROD
US Parts Center
Jun 08, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
My A.O. smith pool pump doesnt seem to be getting electricity. It makes no noise at all when you turn it on. We had a storm last night I don't know if it tripped some sort of switch. I have checked the...
VOLT METER TO THE 2 LINES 230 OR SO ? THE MOTOR MAY BE BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY..USE YOUR ZIP CODE ... GOOD LUCK AND VOTE FOR ME...JAY
May 31, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
I recently turned the breakers in my homes circuit box off and back on, now the whirl pool tub jets won't come on. Is there a reset button on it or something?
This depends on when the tub was installed. By electrical code (NEC) all jetted tubs have to be GFCI protected. You may have to look for an outlet shaped devise with a rest button on it. Some jetted tubs have 2, one for motor and one for heat. Some electricians place the GFCIs in the same area as the motor for the tub. Also by code the motors have to be accessable, so there should be a door that opens up to expose the motor for servicing. You may find the GFCIs there, if so, check that they are reset, and have power. You can use a standard lamp if nothing else to check the power (sometimes multimeters lie, so I like to use something that proves current flow like a lamp, vacuum, drill, etc.)
That should get you on the right track.
Oct 27, 2009 | Jacuzzi Home
Motor hums when turned on
Try this link for help. They suggest emailing before calling:
http://www.mypool.com/introduction.htm
Feb 24, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Century Body Opponent Bag Logo
55 people viewed this question
Top Century Sport & Outdoor - Others Experts
Are you a Century Sport and Outdoor - Other Expert? Answer questions, earn points and help others
