Hp2450 desk jet yellow blinking lights will not print
eagle338
  • 4889 Answers
SOURCE: will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Posted on Oct 27, 2007
SOURCE: hp desk jet f 380
CHECK THE PREVIOUS PENDING PRINT
Posted on Mar 05, 2008
jkreuzweir
  • 16 Answers
SOURCE: NEW Yellow Ink Cartridge Does NOt Print!!
The following is good advise I found here:
A clogged print head on your inkjet printer is not a fine thing. Over time (especially when there's long periods of no printer use) the many tiny holes that make up a modern inkjet printer's head can become clogged with dried ink.
Most printers today have some sort of cleaning routine where either you instruct the printer to go through a cleaning cycle via a program on your computer or you press a squence of buttons on the printer itself to begin the process. A number of these cleanings, in succession, will usually take care of a clogged head--but not always. I recently found my year and a half old Epson Stylus Color 600 unable to print coherently using black ink and no amount of standard cleaning-cycle runthroughs would fix the problem.
On some inkjet printers (HP's for instance) the ink cartridge contains the print head, so changing the cartridge gives you a new, unclogged printhead. My Epson's print head is part of the printer itself, and can only be replaced by a service technician, and the cost is usually very close to the price of the printer itself. I had to come up with something better than that, so I began searching the web to see what people in similar predicaments had done. I found that I my problem was not unique and there were some rather successful remedies floating around.
I discovered that isopropyl alcohol (I bought a bottle of 91% alcohol at the drugstore for ~$3) is a great solvent for this sort of dried ink. There were those that recommended that I take an old, discarded ink jet cartridge, open it, clean it out with the alcohol, fill it back up with alcohol, reseal it, and place it in the printer for a few runs through the printer's self-cleaning method. This proved to be a rather messy endeavor indeed, so I followed a bit of less-agressive advice.
I simply removed the black print cartridge from the printer and dropped 7-10 drops of alcohol down in the ink-recepticle area where the ink cartridge normally sits (there should be a little hole down in there where the ink actually flows from the cartridge into the head), replaced the ink cartridge, and ran a few sessions of the printers head-cleaning routine. It took quite a few cleaning sessions (probably 15-20) with a few pages of text prints thrown in there just to try and move some ink, before it cleared up.
It actually had to sit overnight, with the last few cleanings done the next morning, before all was well--but well it is. Everything works perfectly now, and I don't have to go out and buy a new printer.
To avoid such blockages, it's a good idea to print something, both in color and black&white (if you've got a color printer), once a week or so just to keep things moving. But if you do end up cursed with a blocked print head--this method should take care of you.
Posted on Jan 04, 2009
Touch2Heaven
  • 145 Answers
SOURCE: I HAVE A DESK JET 1220C -FLASHING YELLOW LIGHT
replace cartridges, first...
Posted on Jan 21, 2009
pagebor
  • 2785 Answers
SOURCE: Continous Red light blinking on the printer causing it not to print
plz check the ink cartridge status
Posted on Apr 21, 2009
Yellow light is blinking?
If the bottom amber colored light is blinking, the imaging drum needs replaced.
If the yellow print cartridge light is blinking, then replace the print cartridge (yellow toner).
Mar 24, 2014 | HP c9705a - Color Laser Jet 2500l Printer
Hp color laser jet cp4025 blinking yellow light
Yellow toner is getting low, or check to make sure your print driver is set correctly for this printer.
Mar 22, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
Hp desk jet 380 won't stop blinking
Almost the same...difference that it printing anyway, even I see this E and inc lamp blinking....I know it was color cartridge left and dried out, but software tells that color cartridge is "connected not properly". Cleaned contacts...refilled ink....tried all buttons combinations...maybe, I need somehow to "null" this printers "brain"?
Nov 22, 2011 | HP DeskJet F380 All-In-One Printer
I have a hp desk jet model 710c printer. I have cleaned and aligned the printer. The color red does not print. A test print will not print RED. Do you have any suggestions on what to try?
simple.the ink in the colour cartridge is over.usually pink and yellow mix to form red any of the 1 colour is over.just get your cartridge refilled or buy a new cartridge.the printer is absolutely perfect.
thanks.
Nov 14, 2008 | HP Office Equipment & Supplies
Hp desk jet 920c ink cartridge
hi,
i think your color ink cartridge is near to empty that's why you are experiencing a pause printing..
try to replace it and try to print again..
rey...
Oct 08, 2008 | HP DeskJet 920c InkJet Printer
Hp desk jet f 380
Mar 05, 2008 | HP DeskJet F380 All-In-One Printer
Blicking lights, not printing and not working
Nov 20, 2007 | HP DeskJet 5650 InkJet Printer
jasbo
jasbo
