Question about Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0
Trekstor datastation maxim.u 5oo bg is my back up hard drive. After a power failure, the light goes from red/blue to a solid red. Is there any way to retrieve the data on the drive?
  • pamelapbc May 20, 2011
    No, the hard drive icon is not recognizable to the computer. Are you sure there is no way to retreive the data?
    Hi Bluechip999, I don't mind spending the $49 on a recovery program. The data is very important to me, and only part of it is backed up on a second hard drive.
    I am working on a mac osx 3.06 ghz intel core duo through, not pc. Would I use stellar mac data recovery? Should I try freezing it first, or would it be safer to try the program. I most importantly want the data! Thank you very much for your help.
    Master:
  • 395 Answers
Yes, there may be ways you can try put hard drive in the ziplock bag and put it in the freezer and wait for an hour. Take it out and try it. If it works, try to move your data and quickly as you can. It worked for me before. If disk contains very important data, and you have tried the above step but didn't work, you may want to spend $49.00 for the recovery software. This software works for me more than 90% of the time (you don't have to spend more 2K to send your disk to professional data recovery stores). Here is the link. I have used their product before and it worked, you can call them for support too after purchase the product. http://www.stellarinfo.com/disk-recovery.htm No one can guarantee 100% that your hard drive can be restored including my recommendation . It really depends on bad the damage to your disk is. You just have to take a chance. Good luck. I hope you don't reject my solution. Thanks
Posted on May 20, 2011
  • Blue Chip 999 May 20, 2011
    You can try to put your hard drive in to zip lock, seal it so no water can get in. Freeze it for an hour and try it. This is a temporary fix, enough time for you to move data/file out of this bad drive. It may or may not work. If you concern about data and want to recover quickly, yes, you can buy software. You can also call for support, they can work with you through how to use the software and restore steps if this is your first time use.
    number to call is 1-732-584-2700 if you are in the US. Good luck to you.
    Thank you
    Yes,
    You will go for stellar phoenix Mac data recovery.
    It can recover from any internal/external hard drives, USB flash drives, memory cards and Ipod too.
    Thanks
  • 2,632 Answers
Welcome to Fixya. I would like to know if the hard drive is still detected by the computer? If it is still detected and you see it on the list of drives there is possible way to retrieve the data. However if it is not detected unfortunately there no way you can retrieve it.
Thanks
  • Rofel Lantican
    Rofel Lantican May 20, 2011
    There no way to retrieve that because the drive is bad. Sorry for that
Its is blingking red ang blue and say driver not recogniced
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 10, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
I dropped my TrekStor DataStation maxi g.u - 3.5" External Hard Drive 1TB & USB 2.0 on the floor. When I turn it on the light illuminates however when I plug it into my computer it doesn't even...
Mechanical damage. Last possibility to retrieve the data on it: open the case, extract the hard disk, put it in a desktop and try to access it in there. If even this fails then it's dead, junk it.
Feb 04, 2011 | Trekstor 88470 DataStation duo w.u 1TB...
My 750GB TrekStor external HDD failed. The light at the front of the device went from BLUE to RED and the machine seems to start to boot up the clicks a few times and then nothing. I cannot view the...
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 25, 2010 | Trekstor Datastation maxi t.u SATA 500 GB...
I have a external Trekstor DataStation maxi 500 Gb hard drive. I now have encountered a constant red light and when this happens the drive is not visible in Explorer. When I turn off the power and then...
At the least, the device is "unreliable", and it would be wise to replace it, either by exercising the warranty (if the warranty still is valid), or by opening the enclosure, removing the disk-drive, buying a new (and compatible) disk-drive, inserting the new disk-drive, and closing-up the enclosure, to create a "new" external storage-device.
Sep 18, 2010 | Trekstor Datastation maxi t.u SATA 500 GB...
Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
Jul 10, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Trekstor TrekStor DataStation m.u stopped being recognised by PC
Have you tried going to the manufacturer's website and downloading and installing the drivers for your product?
Sep 03, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Datastation m.u stopped working : (
Dropping a drive can be catastophic but usually isn't.
I suspect you may get lucky and find out it's just some of the circuitry in the trekstor shell that is damaged.
Take the Trekstor unit to your nearest PC shop and ask the technicians there to remove the Hard Drive and put it in a new enclosure to test it. If it works in the new enclosure, buy the enclosure and your done. If it doesn't work in the new enclosure then you may be suffering from worse issues that will require the help of a pro.
Either way let me know how you make out, if you need a pro for the next step, reply back with you location(Country, State, City) and I will refer you to the closest facility who can assist you.
Hope this Helps FixYa,
Chris
Aug 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
DataStation Maxi M.U. 500 Gb blinks red and blue, doesn't read
I just had this problem with both my external drives (I was using the same power cable and just alternating between them). I went and got drive B's power cable and they work fine now. Try replacing the power cable
Jul 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Not loading
You will need some kind of disc utility.
Open the utility with the drive connected and it should show up in the options of drives.
You should then be able to format the drive.
It should then be usable.
If not take it back to the shop..
Dec 16, 2008 | Trekstor DataStation maxi m.u SATA 3.5"...
Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0 Logo
552 people viewed this question
Top Trekstor Computers & Internet Experts
Mohamed Ismail
Mohamed Ismail
Alun Cox
vojvodabudva
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
