Question about Lexmark C543DN Laser Printer
How to install LEXMARK C543DN IMAGING KIT BLACK AND COLOR into a lexmark C543DN. The ink cartridges in the printer are small and compact. The kit comes with a rack and much bigger cartridges. How do you make the two products work togther?
agent1463
SOURCE: Colored Ink problem
Good day sir, My Lexmark z35 color printer doesnt work. I already tried to use the printer settings properly but still failed to print the color ink. Only black ink in printer is printing. Im still hoping that you have any solution for this. pls.. help. thanks!
Posted on Jun 16, 2007
  • 5 Answers
SOURCE: x5470 Lexmark printer
i refilled my lexmark 24 color cartrgide but now the printer does not want to read the cartridge, any help on resetting the thing before i chuck it trew the window
Posted on Apr 23, 2009
  • 52 Answers
SOURCE: refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Posted on May 05, 2009
SOURCE: Refilling Lexmark #4 & #5 ink cartridges for my X2690 printer
the solution to this problem is to BOYCOTT LEXMARK. The quality of their printers is inferior to others such as Canon and HP and Lexmark ink is by far the most expensive of any printer I have owned. They are trying to eliminate refilling by the circuitry in the cartridge so they can resell the used high priced cartridge again.
Posted on Jun 05, 2009
SOURCE: lexmark 3500 wireless
I have put in genuine Lexmark ink catridges but an error states incorrect cartridge can anyone help.
Posted on Mar 29, 2010
Lexmark X7170 will not print in grayscale
i have cannon 3530 xerox machine ... it shows error code 350 ?? any solution ??
Jul 28, 2013 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
Well, jus want to know if I can refill the ink cartdrige? Tks!
If the product is correct as listed...C543DN Laser Printer...it does not use ink. It uses toner in a closed cartridge. You will need to purchase a new cartridge.
Thanks for using Fixya.
Wayne
May 14, 2010 | Lexmark C543DN Laser Printer
Lexmark x3430 need ink cartriage
This is the only information I could find. Didn't your printer come with a black and color ink cartridge? If it did, all you need to do is take the ink cartridge out and write down the numbers written on the cartridge. The only ink cartridge I could positively confirm was the #24 color ink cartridge. The Lexmark website does not list any black ink cartridges for this model. This information was obtained from Officemax.com.
Lexmark - 24 Ink Cartridge - Color
Compatible with Lexmark Z1400 series, X3500 series and X4500 series printers;
Lexmark - 23 Ink Cartridge - Black
Compatible with Z1400 series, X3500 series and X4500 series printers;
Sep 15, 2008 | Computers & Internet
I installed a new "genuine" Lexmark color ink cartridge, but it doesn't work.
then get it replaced by lexmark as the cartridges comes with one year warranty..
Apr 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
Colored Ink problem
Make sure you are using the correct cartridges for the Z35. They should be #26 (color) and #16 (black).
Make sure the contacts are clean where the cartridge connects to the printer electrically. A little alcohol wipe is good for this. Clean contacts on both the cartridge and the carrier in the printer.
Nov 19, 2007 | Lexmark Color Z35 InkJet
Error after reloading color ink
Remover Black and color cartridges. Place small paper towel to protect ink outlet on bottom of printer. Use WD-40 spray on copper surfaces,both sides(Blk& Color). Dry surfaces with paper towel. remove small towel placed in bottom . Reinstall both cartridges. This cleared my 1102 error. Die Rote Baron!
Jun 10, 2007 | Lexmark P4350 All-In-One InkJet Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Lexmark C543DN Laser Printer Logo
150 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
