Question about Polk Audio RTi100 Main / Stereo Speaker
What does red versus black equal?
I'm trying to attach new speakers to a new CD palyer and new receiver... I have ports taht are red, and the otehr is either balck or white. which is positve and which is negative?
    Problem Solver:
  • 7 Answers
From cd player to amp:
connect red from cd to red on the receiver's CD input( and white to white) using RCA cables:
http://en.wikipedia.org/wiki/RCA_connector
Red is usually right channel and white left channel.
From amp to speaker, use speaker cable and and make sure that you connect red to red and black to black. Notice the stripe on the speaker wire to help you do this. you could think red as 'positive' and black as 'negative', though they are not in the theoretical sense, as they carry ac signals.
Posted on Aug 22, 2008
My Kenwood KDC-U453 cd receiver displays "PROTECT" on connection and nothing works - any solutions appreciated!!!!
Pull the radio out, tape off all wires but yellow, red and black. Twist red/ yellow together and attach to positive 12 volt, attach black wire to negative 12 volts. Turn on radio and see if it comes out of protect mode. If it does, you will have to troubleshoot all of the speaker wires to find a short.
Apr 11, 2013 | Kenwood Kdc-u453 Car Audio Radio Iphone...
Do not know how to connect my kappa 60.5cs to my pioneer cd player do they have to go through an external amp?what do i do with the power plugs on the oppisite side why are there 2 per speaker
You need to run RCA cables from the CD player to the CD or AUX input on your amp / receiver unit. If you have a standalone amp, you need some way to control the volume. Basically, if you have a volume control on the front of your amp, you're OK. If not, you should also have a preamplifier that the CD player feeds first.
From the amplifier, then, a single pair of speaker outputs feeds a single pair of inputs on your speakers. The reason for two jack sets on the speakers is for "bi-wiring" or "bi-amping", not necessary for basic stereo reproduction.
So -
CD red/white RCA out -> preamp/receiver red/white CD/AUX input. Amp speaker output (red + / black -) to one red/black input pair on the speakers. An input on the speaker is side by side...
Keep the red to red, black to black when connecting the speakers, or you will wind up with poor sound and weak bass.
Jan 18, 2011 | Infinity US-1 Main / Stereo Speaker
No sound
Make sure the speaker are plugged into the "audio out" ports. Black negative, red positive.
If a dvd players or other system is hooked up, the speaker should hook into that unit, then the unit is hooked to the auxiliary port(s), or the proper ports for each unit: ex: cd/dvd should be plugged into vd/dvd; same for vcr, game system - auxiliary is for pretty much any unit not listed on the backing of the receive - however, some units will still work while plugged into the ports other than auxiliary.
Make sure the receive is selected to the desired device.
If you simply have the speakers plugged into the speaker ports, make sure the speaker themselves are still good - try hooking them up to another source such as a a dvd player equipped with surround sound or speaker adapters that will suffice your speaker wiring.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 28, 2010 | Onkyo TX-SR606 Receiver
I have two remote speakers attached to my sony receiver and they are not working. I am trying to play CD's from my Sony CD player. I did try plugging in earphones and they worked so I assume the receiver...
has to do with the ohm either 4 or 8 of the speakers, sometimes if you try to run pairs of speakers out of the same port (2 on the left port and 2 on the right-4 speakers on 2 ports) the speakers will work but when you set them up on an A or B selector and try to run both A & B at the same time one of the speakers will cut out. Check the OHM ratings and if all else fails run them off the same port using only A.
Nov 29, 2009 | Sony Audio Players & Recorders
Clarion bd216 radio need to know which color wires go where
Black is ground
Yellow is battery
Red is ignition
Blue w/white strip is remote antenna
Mar 09, 2009 | Clarion BD-216 CD Player
TV Audio out to HRT 5650 receiver
You may need to enable the fixed audio output line level from the TV. Some TV`s require you to enter the AUDIO menu/setup selection on the TV remote controller, and then enable the AUDIO OUTPUT Jacks, this will turn off the TV built in speakers and engage the audio RCA Jacks.
Feb 15, 2009 | Yamaha HTR-5650 Receiver
Yamaha rxv 595 receiver shuts down when volume is increased
THE SPEAKER WIRES ARE REVERSED.... On the receiver the red side is always positive and black is always negative.
change + to - or
change - to + on one or more speakers.
positive side--------------------negative side
red --------------------------------black wire
gold wirew/silver--------------silver wirew/gold
white lined----------------------non-white lined
Oct 30, 2008 | Yamaha HTR-5730 Receiver
Denon receiver shutdown
Try turning down your tone controls. Like your bass, treble, or your equalizer. If you hear too much tinny or hissing sounds, the treble has to be turned down, or turn down the upper bands controls on your equalizer to the optimun level. If you hear too much bassy sounds, your bass control has to be turned down, or the lower band controls has to be turned down to the optimun level. If you are planning on turning the volume up, you may have to turn down some of the tone controls to the optimun levels, otherwise, your receiver may shutdown, or you may blow fuses in your speakers. Also make sure you speaker wire polarity is hooked up right. Red wire on the + red terminals, and the black wire on the - black terminals. Also don't have the volume turned up too high to the point where your receiver would have clipping or distortion, or else your receiver may shutdown, or you may blow fuses in your speakers.
If this don't help, then there may be something wrong with your receiver or your speaker.
Apr 05, 2008 | Sherwood RX-4105 Receiver
Wiring a pyramid 903G
red - power
Black - Ground
Blue/Black - rear Left Speaker Positive
Blue - Rear Left Speaker Neg
White/ Black - Front Left Speaker Positive
White - Front Left Speaker Neg
Brown/Black - Rear Right Speaker Positive
Brown - Rear Right Speaker Neg
Yellow/Black - Front Right Speaker Positive
Yellow - Front Right Speaker neg
Green - Left Input Positive
Green/White Left input Neg
Gray Right Input Positive
Gray/White - Right input Neg
Nov 16, 2007 | Pyramid 903G 10-Band Car Equalizer
Polk Audio RTi100 Main / Stereo Speaker Logo
102 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
