Question about Dryers
Drum not turning. Could be belt issue - Dryers
  • 2,926 Answers
It is most likley the belt. One way to see if it is the motor itself would be to turn the dryer on and listen for a hum or indication that the motor is turning. If the motor is turning, the cause is the belt or broken belt tensioner.
Posted on May 20, 2011
Hi, I've got a Kenmore model 110.70052991 and the drum won't rotate. It will intermittently. I have just replaced the belt and it still won't spin consistently. Could it be the
are u able to spin the drum manually? do u hear any sounds? squeaking? scraping? smell anything? the rollers (spinners lol) usually make funny noises when they go out and may still turn but roughly. Bad bearings may be an issue here? However if the motor has bad windings it may not have enough power to run (turn) drum consistantly, u can remove the drum and belt and housing and run the motor by itself and see if it turns and runs easily. with no pressure or weight added? Then add drum and belt, once the drum is added and it stops or runs half hazardly its ur motor ? In some cases the tensioner the belt sits on ( near the motor) can be damaged and cause similar problems , lastly u did add the belt correctly?
Dec 23, 2014 | Kenmore Dryers
Dryer drum not turning
The belt should also be running threw a small pulley beneath the the drum. If it has come off of that pulley the drum will not spin.
Nov 09, 2012 | Dryers
Hi, I have a Beko DRCT70W tumble dryer and the belt keeps breaking. I've replaced it twice in the last month, so I think there must be another fault with the dryer which is causing this. The drum...
hi folks the beko tumble dryers have a felt seal that runs along the front of the drum that wears through causing load on the drum, belt and motor causing the belt to melt and snap, replace the felt you will have no more issues, i got mine off of ebay pretty cheap
Feb 08, 2011 | Dryers
Drum is making a knocking noise
it could be the rear drum bearing going out or the rear drum rollers going bad or the roller wheels beginning to flatspot or the front rollers in the same shape,you would need to remove the front cover on the unit by removing the lower kick panel screws,then remove the top cover and removing the drum belt,then remove the drum from the machine to examine all the above issues noted
Apr 27, 2010 | Kenmore 63942 Dryer
Drum does not spin. possibly a belt issue?
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please rate me,
Thank you
Dec 01, 2009 | KitchenAid KEYS850LQ Electric Dryer
The drum won't spin or agitate the cause is the belt slipping off
There is a mechanical alignment problem beyond your ability to fix. Get a repair Tech and pay for a service call.
Oct 24, 2009 | Washing Machines
Dryer makes a squeal, like a drive belt, when under load. Where and how do I inspect for a belt issue?
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Oct 14, 2009 | GE Dryers
Dryer power problems
Yes, all dryers have a belt that turns the drum. Chances are the belt and heat problems are 2 separate issues.. The belt turns the drum from a motor mounted inside the unit, your electric dryer has a heater element/coils that heats the drum your clothes are in. The belt could be bad and heat element also but both at exactly the same time is rare. Try unplugging the unit for about 5minutes and see if it resets. My washer does that sometimes and I have to unplug
Aug 07, 2009 | Whirlpool WED6400S Electric Dryer
Maytag drum
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Dryers Experts
